| Hi,
I have had a water softener with other assorted water treatment equipment (neutralizer, aerator, sediment filter) that came with our 1972 house with well. I need to replace the equipment as it no longer is working correctly. Te water results from a certified lab on the raw water are: Hardness 58 mg/L Iron 1.09 mg/l Manganese 0.11 mg/l Color 100+ pH 7.08 Turbidity 14 NTU The iron is dissolved I believe (although the test results didn't specify). I know that water softeners are used to remove iron/manganese but it seems unnecessary since my water isn't hard.
| I'm not an expert by any means but you might want to consider this company also. http://www.qualitywaterforless.com/category_s/1.htm Just bought a Water Softner and Carbon Unit off of them, easy to deal with and talk to. Will answer all your questions. |
| merlin 2552, for more on Terminox systems, check this thread: http://ths.gardenweb.com/forums/load/build/msg0909380131364.html particularily member 'mydreamhome's' posts |
- Posted by aliceinwonderland_id (My Page) on Sat, Nov 19, 11 at 18:49
| One question to start us off: Does your water have color coming out of the tap, or does it start clear and then darken over a period of time? |
Return to the Plumbing Forum
