| Good morning all... I have a Bunn counter top electric coffee maker...
In the water heating portion of the CM there is a build-up of scale, whick plugs the siphoning mechanism that drips water thru the coffee filter and brews the coffee.. Cleaning weekly is becoming a real chore... Question.. Has anyone used a water conditioner, filter, reverse osmosis, that eliminates this problem ???.. i.e. Brita, Zero water etc.. There are no visible particulates in the water.. just lots of stuff that makes scale.. I moved this thread from appliances to here seeking more advice....Dave PS... 4+ pots of coffee daily.... Softener removed awhile back... |
- Posted by justalurker (My Page) on Wed, Nov 16, 11 at 13:06
| You have hard water. When the water is heated the calcium precipitates out of the water. To cure the disease you need to treat the hardness with a water softener. Depending on the hardness and other things in the water you may also want to install a reverse osmosis (RO). I have a 20 year old Bunn and have never had to clean it and my water is 30 gpg hard. The same scale you see in the Bunn is in every pipe, appliance, and plumbing fixture in your home. Your first step is a water test... are you on a well or a water system? |
| We are on a water assoc... I received a water analysis some time back and can't recall what the hardness was... |
- Posted by justalurker (My Page) on Fri, Nov 18, 11 at 11:59
| You said "Softener removed awhile back"... why? You were softening your water to remove the hardness. Then you removed the softener, Now you are complaining about scaling in your Bunn. You have diagnosed the problem and had the solution. Add-on filters do not remove hardness. If you install an RO on hard water you will be replacing membrane often and that is very costly. Get your water tested and have a correctly sized and set up softener installed. Depending on the hardness and other things in the water you may also want to install a reverse osmosis (RO). |
Return to the Plumbing Forum
