New kitchen faucet drips after shutoff, then stops
Posted by rekoil (My Page) on
Sat, Nov 22, 08 at 10:54
Hi,
We just installed a new kitchen sink and Hansgrohe faucet as part of our remodel. It's a single-lever control with a pull-down spray head.
We've noticed that after the water is shut off, the faucet drips (fast at first, then slower) for a short period of time after the valve is closed. While the drips do stop after about 15-20 seconds, I'd like to be sure that this isn't a defect or a sign of future failure. My wife just put a bowl underneath it to make sure there are no slow leaks, and we've seen about two drips in the past 15 minutes (immediately after a shutoff).
I will note that due to the pull-down spray, the water line between the control lever and the faucet head is quite long - about 3 feet. So there is quite a bit of water beyond the valve after water pressure is removed.
So should I be concerned here?
RE: New kitchen faucet drips after shutoff, then stops
To follow up, after about 90 minutes, it's apparent that there are no new drips from the faucet, so I think we don't have an ongoing leak to worry about. I am still concerned about the drips immediately after shutoff though - I'd like to know if this is something to be expected or not with the longer supply line between the shutoff valve and the faucet head.
Most likely its the water left in the line after shutoff. very typical. If it was continuous then I would be concerned
If you want to have peace of mind, you can contact the Manufacturer through the link below.
Here is a link that might be useful: Hansgrohe Technical Assistance
I recently purchased a Grohe 33980 kitchen faucet and it drips about 7-9 times after shutoff. I asked Grohe people and they had no solution. Does anyone have a fix for this problem?
Any water above the level of the outlet in the faucet end is going to drip out after shutoff.
The same thing happens with most of the 'high arc' faucets.
The water is past the shut off valve and standing in the lines and hoses.
There is likely no practical way to prevent it.
Some pot fillers dripped as the range heated up. The water in the spout expanded as it got warmer.
