| My septic tank feeds a diverter valve, a 4" NDS 575, that can send effluent to either or both of two leach lines. I believe the valve is sending all to one of the two lines and I need to change positions to the other line to rest the overused line.
Problem is that the valve will not turn. I wiggles a few degrees but won't turn anywhere the 90 degree quarter turn I need. The tank pumper told me to oil it and force it or even just pull or drill out the valve's innards to allow free flow to either line. That may work but it will not properly rest the line that is not draining well. The tank was in good shape and I did not send the wrong stuff down the line. I prefer to turn the valve and not to break it in the process since removal will be quite unpleasant (under a large wooden deck). Due to access and design, the handle of the valve is not convenient to grab and is not strong enough to allow serious torque. I have made a 'handle' with two 2x4s to grab the thin valve handle and raise the grip up a couple of feet to just above the deck level. I could make a better handle with 2x6s which would allow me to apply more torque. But I could break it if I do not know of a better way to get it loose first.
Any ideas out there? |
- Posted by justalurker (My Page) on Sun, Oct 7, 12 at 20:37
| I had our tank replaced and a second field added a couple years ago. Included in the job was a bull valve on the field side of the tank output to do the same job as your valve. The valve was complete white plastic (PVC?). I exercise the valve every 30 days for peace of mind. always turns smooth. The valves can be replaced with some shovel work if yours should fail or break. It's a good idea to alternate fields so I'd solve this problem rather than ignore it. |
| Thanks but not a good option and my last choice. The pipes out of the valve are 24" below surface and the surface is another 18" under a deck. Only 16" between the deck joists. Deck would need to be removed just to dig by hand. Lousy human being access so I do not want to replace unless a last resort. Looking for someone that unstuck a similar valve. Al |
- Posted by justalurker (My Page) on Sun, Oct 7, 12 at 21:23
| You can try something like PB Blaster or Kroil. Both are sprays and excel at loosening stuck stuff. Multiple applications over time works wonders. Make yourself a better, heavier duty tool to turn the valve. Perhaps a 3" diameter wooden dowel crosscut on the end to fit the valve? |
| Good suggestion. I usually like to know why something is stuck so I can be sure lube is really the way to go. I tried WD40 butr couyld not spray it well since the valve is 12" done the riseer pipe and aerosol cans do not like spraying off level. Tried some light oil but it was not feeling like the right thing so I stopped and went on vacation! Lacking any other suggestion about why such a valve could be stuck, your idea is my next step. Thanks. Al |
- Posted by justalurker (My Page) on Mon, Oct 8, 12 at 22:52
| Your'e doubly cursed... metal valve and restricted access. Someone planned ahead. WD isn't really great for freeing up seized metal parts. It was designed to displace water. Make an extension for the PB Blaster or Kroil spray can... Find some wire that is roughly the diameter of the spray nozzle tube and as long as you need it. Strip off the insulation and use that to extend the spray nozzle tube. Either tape the two together or use shrink wrap to connect them. |
- Posted by justalurker (My Page) on Mon, Oct 8, 12 at 22:55
| BTW, the NDS 575 valve is now ABS... click here |
| Not sure what I said but the valve is black plastic: both the part that turns and the housing that is exposed. Regardless, the technique for getting the penetrant to the right spot is a good one. I will give it a try. The NDS sheet says that to 'remove inner stem' to allow all the ports to be connected. I assume (cannot see without digging) that one is to the tank, two to the leach lines and one is capped off. I I pull the stem, flow depends on gravity to take from the tank and let it take the path of least resistance to either or both lines. They do not say how to remove the stem but I clamped on to the 'handle' with some pliers and could not pull it out. Again, I am going slow and did not pull like my life depended upon getting it out! Afraid to break the plastic handle. Maybe I am making a mountain from a molehill but I do not need another PhD in the school of hard knocks. I got too many already... |
- Posted by piedmontnc (My Page) on Wed, Oct 10, 12 at 15:07
| Do you have the possibility of just running a new supply line from the tank to a new diversion valve where you'll have convenient access? |
| I finally got a call back from the valve manufacturer, NDS. The tech looked at the drawings for the valve, the guts, not just the one on the web. He said I can try any lube that does not melt the plastic and simple pull, force, etc. If it remains stuck, he said to just pull the stem (the movable part) out of the valve body since there is nothing to hold it in like a retainer clip. If I break it, he said to just get it out any way I can without breaking the housing. He would then send me a replacement stem, no charge. That is a nice offer and really lets me go forward with trying to turn it by having a way out if I break it. Any other options make things hard and I will try to avoid any shovel work. |
- Posted by justalurker (My Page) on Thu, Oct 11, 12 at 1:51
| Get a pair of vise grips on the valve fin(?) and use a slide hammer to pull the guts. A slide hammer is the perfect tool cause there's probably only o-rings on the valve and that's all the friction you'll need to beat. A piece of all thread or steel rod with a hook at each end from vise grip to above grade should get you the rise you need. You might want to get someone to put some down force on the valve body with a broom handle or something similar while you remove the guts or you risk breaking the valve body or a connection. Don't pull the valve guts till you have the replacement parts in your hand. Use liberal amount of plumber's silicone grease on the new parts before inserting... and time the direction of the valve correctly. |
| Excellant advice! It is a fin that I must grab and avoid breaking off. And the sugestion about holding down the valve housing is great since I only want to be putting force on the part I want to move. The grease I have and will use. Have it for swimming pool o-rings and works but messy. Will get the stem and report my success or other result. Thanks again. Al |
Return to the Plumbing Forum
