| I've been reading and trying to get educated on recirc pumps in order to figure out what to do for our situation. Can anyone point me to a recirc pump 101 type of site or provide some commentary on our situation?
We have an L-shaped house with the garage at the base of the L and the master bath as far away from it as possible. It takes forever to get the hot water to the shower! We are in the midst of a remodel where the house will become a U-shaped house. The new part of the house will be a kitchen so there is plumbing work that needs to be done. We will use a standard water heater (our current one is relatively new so we are not replacing it)but we wanted to consider a recirc pump option to solve the water waste problem in the master bath. I have one plumber telling me to run a new dedicated line with the pump at the hot water tank in the garage and set the pump to a timer. I have another telling me to install a pump underneath the sink in the master bath - which would require some electrical work, but not a dedicated line. Something like this:
Any help is greatly appreciated! Thanks! |
Here is a link that might be useful: Under the sink recirc pump
- Posted by justalurker (My Page) on Thu, Oct 11, 12 at 15:04
| Search this forum for laing and autocirc and Google the same. I have a similar situation as yours and have very happy with my retrofit recirc. Saves gobs of water, cost's pennies to run, and an EZ non-invasive DIY install. It is best to do a recirc with a dedicated line but that can be VERY expensive and VERY inconvenient after the house is built. |
Return to the Plumbing Forum
