Return to the Plumbing Forum
Flip stop tub drain access panel?
sherrilea (
Fri, Oct 7, 11 at 14:03
| I'm building a new house in California and was just informed by the plumber that I cannot have a flip stop waste and overflow drain in my tub without it requiring an access panel located directly behind these fittings (per code).
Can anyone tell me if this is true? I thought the requirement was for slip joint connections. Maybe flip stop mechanisms only come with slip joint connections? |
RE: Flip stop tub drain access panel?
| Where are you putting the stop valves for the tub? |
| Code does not require stop valves for tubs or showers... I just looked through a stack of my catalogs, then did a quick online search but I am not finding any glue-in or solder in waste & overflow kits with a flip lever on the overflow. What I did find was "lift & turn", & "toe taps" ( Personally I prefer the toe tap) |
brickeyee, not sure I know how to answer your question. My main concern is with the master air/soaker tub. Here is the inspiration picture which is similar to our set up:
We have a water closet to the left which will have an access panel for the motor. To the right is the shower. Center front is the tub drain which we want a cable drain stop mechanism. But we are told it will require another access panel. |
RE: Flip stop tub drain access panel??
| Thanks lazypup. I'm resigned to going with a "lift & turn" or a "toe tap" stop for my guest baths. But I want a cable drain mechanism for my deep master tub for convenience. Don't want to have to lean way over to reach a lift and turn , or stick my foot in for a toe tap, when I want to fill the tub. Problem is this type of stop mechanism supposedly requires an access door that has to be directly behind - not under or to the side. This give me heartache with regards to the finish tiling :-( |
| You may be able to do something like this: |
Here is a link that might be useful: Schluter
| Thanks for the link palimpsest. Interesting concept. I wonder if anyone has done something like this. Would sure like to see pictures of it in place - both open and closed. |
| "Code does not require stop valves for tubs or showers..." A rather poor setup. Remember the code is the MINIMUM. |
| I spent over 30 yrs in the plumbing trade and I could count on one hand how many tubs or showers I ever saw that had shutoff valves and nearly every one of those was installed as a DIY or a fly-by-night wannabee plumber. On the other hand, putting the entire bathroom on zone valves is quite common. |
