| my new WM only opens from right to left, forcing me to place it further from the old drain pipe.
I've read everywhere that current code requires a 2" drain pipe. from out of the wall, I see 1.5" pipe.
is he correct or do i need to break the wall and change it to a 2" pipe?
house was built in 1965.
thanks.
| one more addition. i am going by california plumbing code. I was not able to find city/County specific codes. |
- Posted by live_wire_oak (My Page) on Sun, Oct 7, 12 at 13:50
| If you don't touch it, then it's fine at the current 1 1/2" that currently exists. Just buy a longer drain hose. If you start redoing stuff, then yes, you've got to open up the wall and make it all 2" to the main drain, which will also mean opening up the floor for access to change that portion of the piping as well. |
| is it possible to extend the drain hose 4-5 feet? do i hook it up high enough so that the extension slopes down to the original drain? |
Return to the Plumbing Forum
