| Not are what the problem is. Brand is Koehler 1.6 gal per flush
Advise please |
| Water running but not filling or no water staying in tank? |
| Running but not filling |
| your flapper isn't sealing. |
| tjdabomb is probably right. This means: 1) you need to check to see if there is anything stuck to the sealing part of the flapper or the porcelain rim it bears against that might prevent complete sealing; or 2) you need to check the chain or whatever it is that connects the flush lever to the flapper (sometimes they get a kink in them and the flapper doesn't go down all the way); or 3) you need to get a new flapper ($5). Toilets are pretty simple,,,you should be able to prove to yourself that the flapper is at fault by pressing down on it and forcing it to seal: the tank should fill up with your hand holding the flapper in place (don't worry...the water is clean!). Please report back after you investigate further. (One other less-likely possibility: I just fixed a neighbor's toilet with this symptom. The nut on the inside of the tank that holds the flush handle in place was a little too tight and the handle would sometimes stay depressed, so I backed it off about a quarter turn so it could move easily and return to the normal position. |
Return to the Plumbing Forum
