| Is there any rule of thumb on whether 6 elbows on 1/2 copper is too many for good water flow to a shower mixer? I'm installing a Kohler with their large shower head. I can either use the existing supply lines with 5/6 elbows total front the crawlspace ceiling line below, or I can cut out 2/ea by routing more directly in the crawlspace. Do you think we will have a noticeable improvement in water flow or not? Thanks much. |
- Posted by lazypup (lazypup@yahoo.com) on Mon, Oct 31, 11 at 11:59
| A copper 90deg elbow has a fitting insertion loss equal to 1" of straight copper pipe, therefore if you have 6 elbows it would have the same effect as adding another 6" on a straight run of pipe. At the flow rates of a shower head the friction head loss would be almost negligible. |
| Thanks lazypup. |
- Posted by lazypup (lazypup@yahoo.com) on Tue, Nov 1, 11 at 15:35
| Just out of curiosity I worked it out. Each elbow is has an insertion loss equivalent to 1" of 1/2" copper pipe so 6 elbows would be equivalent to adding 6" or 1/2foot of pipe. At 3gpm the "Friction Head Loss" is 3.2psi/100ft of pipe which then equals 0.032psi/ft. 1/2ft of pipe would then cause a friction head loss of 0.16psi. By contrast, if you were to raise the shower head 6" that would cause a "Vertical static head loss" of 0.2195psi so the 6 elbows would only cause approximately 1/13 as much loss as raising the shower head 6". |
| Very interesting. I WAS going to raise the shower head a few inches. Practically-speaking, do I need to rethink that? This is a first floor bathroom, if that helps. |
- Posted by lazypup (lazypup@yahoo.com) on Wed, Nov 2, 11 at 9:26
| The Vertical Static Head Loss is 0.434psi per foot of vertical rise and here again, the loss is so slight that it doesn't bear consideration. |
| For 1/2" pipe, the equivalent length is about one foot per 90, which will give you under 0.4psi loss at 3gpm for your 6 elbows. |
Here is a link that might be useful: Copper.org tubing handbook
Return to the Plumbing Forum
