| Do I have to vent a washing machine drain? There is room around where the washer drain hose fits into the 1-1/2" drain pipe for air to be pulled in when the washer drains. But I am not sure what plumbing code requires.
Thanks for holding my hand through this re-plumbing of my daughter's old bungalow. |
| "There is room around where the washer drain hose fits into the 1-1/2" drain pipe for air to be pulled in when the washer drains." That has nothing to do with plumbing venting. Venting is to allow the water to flow in the waste lines without creating suction that could empty the traps used to keep sewer gas from entering your house. You know that gurgle the toilet makes as it flushes? That is desired in that case sine the water in the bowl is restored as the tank fills. If that happens on other drains there is nothing that will refill the trap. |
- Posted by bus_driver (My Page) on Tue, Sep 21, 10 at 8:50
| The washer might, depending on the applicable code, be able to vent with a Studor vent. Check the code for that specific location. |
| There are many rules about venting under each of the plumbing codes. It is not easy to advise. After (downstream of) the P trap at the bottom of the stand pipe, a vent is required under every code I know of. Other rules apply too. For example, there are limits on what other fixtures' drains can be plumbed onto that same Trap arm. A washer's stand pipe is an "open" drain which will gurgle. http://www.terrylove.com/forums/index.php has forums for various plumbing codes. hth |
Return to the Plumbing Forum
