Water Heater Won't Drain
Posted by wxman5 (My Page) on
Mon, Sep 5, 11 at 16:33
I'm replacing my 20-year-old gas water heater with a new one, but can't seem to get the old unit to drain. I shut off the gas and water supplies and attached a hose to the drain valve, turned on a few hot water taps in the house to break any vacuum, but all I get is about 5 gallons of clear water (no rust or sediment) that drains out. I can turn the water supply back on with the drain-valve open and water flows out with good pressure. In short, my water heater is acting like it only has a 5 gallon capacity. (Its a 50-gallon unit.) Any suggestions?
RE: Water Heater Won't Drain
Open the temperature and pressure relief valve on the side near the top of the heater. Or it may be on the top.
If you are using the typical plastic outlet on the tank they do not have much clearance.
Even a small amount of scale will clog the drain.
Sounds to me like there's enough crud in there to block the passage once it starts flowing. Suggest the "coat hanger trick"....by which I mean running a stiff wire up through the open valve and wiggle it around to dislodge the obstructions. If there's that much crud in there, I suspect you may have to stay right there and keep wiggling the wire while it dribbles out annoyingly slowly.
