Fri, Aug 3, 12 at 20:23
| Just a quick question if anyone know the answer. Our house was built in 1998, we bought it about two years ago. The other day, I was installing a garbage disposal under the kitchen sink and had to re-do the drain pipes under there.
Anyway, when I took the drainpipes apart underneath the kitchen sink, they were about 50-60% clogged with a black/brown, greasy-looking, jelly type stuff that was just real nasty. It smelled kind of like sewage, not real strong but definitely stinky. Is this normal? I dug out what I could and replaced most of the under-sink drain pipes. I just didn't know if this is normal. Thanks! |
| Common, but not normal. It's grease. Sort of like clogging of the arteries for your drain, which slows down the water and makes it clog again that much faster. Aside from scraping it out with a paint stick (that's what i do), it would proably be helpful to run plenty of hot water, followed by draining a basin full of hot water soapy Ajax water. Maybe a foaming drain cleaner would help, too, though one shouldn't get in the habit of using drain cleaners too often. |
| Thanks for the reply. I'm sort of wondering how far down in the 'system' that stuff goes. Don't guess there's a whole lot I can do about it short of what you suggest. Thanks again. |
- Posted by bus_driver (My Page) on Sat, Aug 4, 12 at 17:41
| Grease down the drain is bad for your plumbing, bad for septic tanks, and bad for municipal sewage treatment plants. |
| It may not run that far...the pipes under the sink -- particularly the P-trap -- are where most of this stuff settles. However, you may need to re-consider what goes down the sink. Does anyone routinely pour grease of any kind down the drain while cooking, rather than disposing of it in the garbage. Do you have a garbage disposal, and if so are you putting anything in it that could cause grease buildup in the pipes? |
- Posted by weedmeister (My Page) on Thu, Aug 9, 12 at 18:35
| I remember watching a TOH episode where the homeowner was adding a basement toilet. They needed to attach to a drain that came from the kitchen above. When they cut the pipe, it was filled with the same crap, nearly completely blocked. This was about 10 feet from where the pipe went up into the kitchen. They stated afterwards that they went in and snaked the drain line for the homeowner to clean that crap out. |
Return to the Plumbing Forum
