Water Softener - first time home owner
Posted by AkulaNewHomeOwner (My Page) on
Mon, Aug 6, 12 at 18:19
Hello,
We are first time home owner and are considering getting water softener system (especially for the tankless water heater, as its spec for water is 200 mg/L for hardness). We are completely new to water softener (or plumbing or anything home improvement related), so please forgive me if I sound too newbiesh. I did spend few hours reading this forum but not sure that's enough.
Here are some rough facts and estimates:
Hardness: 10~15 grains per gallon
Iron: not an issue
TDS: 320
Water usage: we are very frugal (230 gallons per month; need to confirm this number after I got home as my wife is not very good at math)
Family and home size: growing family, 2 adults, 1 toddler at 3 year old and perhaps more coming. Home only 1800 sqft with 2.5 bathrooms.
Pipe size: 1.25" with a loop inside the garage
SFR: 9 gallons per minute (7 seconds to fill 1 gallon container with both hot and cold water on at the tub)
Here is the spec what the Watts dealer (via Costco) recommends (I left out unimportant ones):
Maximum compensated hardness (grains) 90
Maximum ferrous iron reduction 10 ppm
Minimum pH 7
Super Fine Mesh Resin 1 cu ft.
Salt usage (lbs) / Capacity (HC - High Capacity) 10 /30,000
Salt usage (lbs) / Capacity (HE - High Efficiency) 5 / 1,200
peak Flow rate / psi drop 10 gpm /14.5
Pressure drop @ service flow rate of 4 gpm 4.0 psi
Water Pressure (minimun -maximum psi) 20 /120
Plumbing Connections 3 /4 - 1" MNPT
It looks like we don't really need a large softener, but SPF and pipe size may require a larger system. We never had softener before and is not sure about the benefits, so we are not sure we need to spend $2k+ toward a large system (we prefer Culligan, Ecowater, Kinetico, or local dealers as we are not DIY types and willing pay a little more).
Any help is appreciated.
RE: Water Softener - first time home owner
Soft water pros... longer service life for plumbing, appliances, and fixtures. Your tankless will thank you. Clothes last longer and are softer to wear. You'll use less soap and detergent and shampoo. It will be a long time before you fix a leaky faucet.
Based on your numbers and occupancy (including future baby for 4th person) here's my recommendation if you're on a water system. If you're on a well then things change.
1.5 cu ft (standard hi-capacity 10% cross-linked resin... NOT FINE MESH) softener using a Fleck 7000SXT or Clack WS1 control valve on your 1.25" softener loop with appropriate connectors so you don't reduce the plumbing size. Choice of brine tank with salt grid and Fleck 2310 safety float brine pickup. A bypass will come with either control valve and you'll want a top basket for the control valve AND a gravel under bed. This is the setup you want... don't let anyone talk you out of it.
Set up for efficiency it will regenerate every 8 days or so and use about one bag of salt a month.
Use those specs and shop around for a local water treatment professional. They won't program the softener correctly but I can give you the #s and you make them set it up that way.
With 15 gpg hardness and 320 TDS you should consider an under sink RO in the kitchen for drinking, cooking, and ice making water.
Thanks justalurker for the quick response!
We are also considering the rental program from Culligan (I know it is much more expensive value wise; but no need to worry about regeneration and salt refilling as Culligan will swap out the tanks for us). The sales recommends twin tanks, each with 3/4" pipe. Would that work with our 1.25" pipe?
AFAIK code prohibits reducing water service size. That said, it is done but unless it would be difficult or dramatically more costly why not keep the correct size and not sacrifice any water pressure or flow? Culligan should know better.
As far as value, the softener I'm recommending can be ordered online and shipped to your house for about $575. You'd need to assemble it and have it plumbed in so add $300 for a plumber to do it and then compare that $875 with what you'll spend renting a Culligan for just one year let alone 2, 3, or 4 years. Regeneration is done at 2AM with no attention required and putting one bag of salt a month in the brine tank is pretty EZ when the softener is in the garage and not a basement.
You bought a house and aren't renting one...
Thanks again justalurker.
So this is the one you are recommending from Ohio Pure Water?
Fleck 7000SXT Electronic 1-1/4 Inch Meter On Demand Control
# 10x54 resin tank
# 1.5 cubic feet of resin
# 12 gpm service flow rate
# 2.5 gpm backwash flow rate
http://www.ohiopurewater.com/shop/customer/product.php?productid=18651 &cat=632&page=1#
The price is exactly @ $575 but I am not sure about the crosslink being 10%. for the connection I will go with 1.25" brass sweat option.
Can I also use Potassium chloride for this softener to water plants?
Here is a link that might be useful: Softener from Ohio Pure Water
That is the configuration I recommend with the additions I posted...
* Fleck 2310 safety float in brine tank
* top basket for the control valve AND a gravel under bed
* standard hi-capacity 10% cross-linked resin
Don't order online... call on the phone and tell them what you want and don't get talked out of anything and don't let them charge you more.
KCl can be used in any ion exchange softener but the salt dose will need to be changed slightly. KCl has gotten very expensive so you may not want to go that route. My wife is having great success watering her house plants with NaCl softened water with no bad effects.
