basement washer hook up
Posted by chuckbendig (My Page) on
Wed, Aug 17, 11 at 16:11
My washer hookup was installed by a renovation contractor in November of last year. The washer hookup is in the basement, and ties into the sanitary sewer which is about 4 feet above the basement floor. Sewer water is coming out of the washer hookup when we use the plumbing on the first floor. How do I fix this problem?
RE: basement washer hook up
Drain line seems to be clogged downstream. Snake from the washer drain for a good length and see if that helps.
How did they make teh washer tie in?
Does it have a trap & code approved standpipe?
You don't fix it. Your ding-bat contractor fixes it....and reimburses you for any damage done.
Send picture. Sounds like you do not have a standpipe.
