escutcheon or plate or both?
Posted by hifixer (My Page) on
Sun, Aug 28, 11 at 1:36
I live in a condo and want to change the shower faucet and valve. A plumber told me that a larger hole would have to be cut in the shower wall around the valve to gain easier access to it. After the valve is replaced a large plate would cover the hole. My question is: would the escutcheon go over the plate or would the plate replace the escutcheon? Do the plates come in different finishes so that I can pick any finish I want for my fixtures?
RE: escutcheon or plate or both?
Not sure about the finishes for remodel plates, but if existing one works, you should look into trim kits for that model instead. You need to know the mfr, then call their customer service and describe how your fixture works (eg "pull and turn, or just turn, etc) and they can help. Good luck.
Hi, When a valve is replaced a large hole is cut to replace the valve. The plumber will purcase a smitty plate that is designed to work with the type of valve you want ie. single hole or three hole. The smitty plate will be bigger than the hole that was cut. The escutcheons will fit on the plate. I have seen plates made of plastic or stainless steel.
Good Luck Woodbutcher
