| New to this forum. We just bought a used home with a newer well. We have a holding tank, Well and a separate small "pump house" building that holds the pressure tank, 1/2 hp pump. Both the well pump and the pressure pump run a 20amp circuit.
Problem 1. In the "pump house" the pressure tank is plumbed into the current well and the old well with not visible shut off. Also the irrigation system is "T" in to this same plumbing. It is a horrible plumbing job with spare elbow propping up where the pressure pump line t-off to the pressure tank then into the house through a sediment filter.
 Q. Should the second well be disconnected from the circuit? It is still wired and the well is more seasonal. (I have not attempted to turn it on, as I don't want to push rust and sediment in to the house.
Q. Is this really a problem? Seems to me that the biggest issue is the holding tank (3,000 gal) is not turning over water at all. Water quality is more the issue with a seemingly stagnant tank of water? Last Question, does aerating my water into the holding tank really eliminate the sulfur smell in all our water? The holding tank has a float system connected to the well pump; the pressure pump is correctly connect to the pressure switch at the pressure tank and holds 80 lbs with our leaking. Let me add one more thing, they directly connected the irrigation to the system on the outside of the "pump house" with only a T handle.
I know I can fix it, but where does one start? I want to start with plumbing at the well, and let the water enter the holding tank from the top rather than the bottom as it does, and let it aerate the tank to get rid of the sulphur odor. (I will vent the tank as well. I know this is a lot but I need to get moving on this before winter sets in.
| So, let's see if I read this correctly. You have two wells that feed into a 3,000 gal. holding tank. One pump is not currently used. The pressure pump feeds the house and an irrigation system. You have an odor in the water and you don't use the second well, but have sufficient water. "does aerating my water into the holding tank really eliminate the sulfur smell in all our water?" - I doubt it. FWIW, changing the pressure tank got rid of the sulfer smell in my neighbor's water. It was the tank, or the bladder in it, that was the culprit. My suspicion is that the holding tank was put in to ensure enough water to meet the household/irrigation demand in times when the well couldn't meet the needed flow rate. (Are you sure the tank meets sanitary standards for household water?) That may be why you also have a new well. I would not have them on the same circuit or connected to the same plumbing system, especially if one were in questionable condition. |
Return to the Plumbing Forum
