Are Sharkbite and other quick connect fittings reliable?
Posted by amateurplumber (My Page) on
Thu, Jul 18, 13 at 21:54
I want to install a water softener and am wondering if these are reliable and if there's anything else I should know about them. Do they restrict flow any more than a normal soldered fitting? Any significant difference between the Sharkbite (with teeth) and the quick connects (which seem to have no teeth, namely Watts brand)?
Thanks a ton!
RE: Are Sharkbite and other quick connect fittings reliable?
Sharkbite is in wide use by plumbers on permited jobs so I would say they have proved themselves. Ask your local inspector which brands are approved in thier jursdiction.
They may have a fraction of a percent LESS restriction compared to soldered fittings.
