Sun, Jul 8, 12 at 16:49
| I pulled the thingy that keeps the water from draining out of the tub out of the drain in order to clean out accumulated hair. I don't know what it is called -- it's the metal piece that goes up and down when you turn the handle. A drain plug, maybe?
Anyway, I pulled out the entire thing out and now I can't get it back in. Any tips on how to get this back in place? FWIW, my faucet, etc are Kohler Kelston, so I am guessing this came with the other fixtures. |
| Sounds like you removed the tub drain linkage assembly. I would lube it with plumber's grease, the reinsert. Hopefully it slides back in and drops into place after a few attempts. |
| Thanks, I'll give it a try. |
| Hey, I tried it and it worked! I also had to jiggle the handle to get the tub drain linkage to drop into place. Now I can take a bath without sticking my toe in the drain. ;) |
| Good job! |
- Posted by bus_driver (My Page) on Mon, Jul 9, 12 at 21:47
Return to the Plumbing Forum
