tapping/knocking sound only in warm weather?
Posted by sovra (My Page) on
Mon, Jul 9, 12 at 10:33
All last summer and now this year, too, I have had a problem with an intermittent tapping/knocking sound in my house. The sound only occurs in warmer weather, but it occurs day and night. Last year I thought that it might be animal-related (like a woodpecker of some sort), but the animal/bug control company I called last year saw no signs of damage and said that the day/night pattern ruled out birds. I now think it must be plumbing-related because I can feel a couple of the water pipes in the basement vibrating when the sound is happening.
Can anyone suggest what I ask my plumber to look for when dealing with it? The sound is intermittent so I can't count on it happening when he's here. Plus my usual plumber is somewhat hard of hearing. I'd like him to do the work if possible, but I'm not sure he can hear the problem.
RE: tapping/knocking sound only in warm weather?
Seems like a vibrating pipe at a point where it is strapped or clamped to the house framing. You should try to isolate the sound location a bit more. (In the winter, this typically happens when hot water suddenly goes through a cool pipe and the pipe expands rapidly.)
Next time the sound happens, hold one of those vibrating pipes firmly and see if goes away, etc. then proceed from there to locate the pipe strap/clamp in question. Also, just securing the vibrating pipe where you can access it might help.
Thanks, Homebound! Will do!
