Help - new kitchen drains leak - see pic
Posted by jally (My Page) on
Tue, Jun 12, 12 at 23:01
Hi, my 1950s kitchen drain consistently clogs, probably due to those ancient years of abuse by my mom, who used to let loads of gooey fat down the drain. So i recently had a plumber over to unclog the drain, then asked him to replace it with a PVC drain.
Here's a pic of the 1.5" drain he installed:
After installation last week, the drain kept leaking.
I posted numbers on my pic. corresponding to the order in which the drain leaked.
After the 1st leak, I contacted him, and he came over to adjust it.
But then it leaked in the 2nd & 3rd areas (see TWO/THREE labeled in the pic).
As of now, it seems to have stopped leaking for the most part.
But I'm still concerned, because some guys I spoke with (including a local hardware store) said that metal nuts should have been attached to the metal strainers (rather than the plastic ones depicted.
Yet another guy said that he would not only place metal nuts, but also lengths of metal pipe descending from the metal nuts (directly beneath the strainers.
The plumber is stating that he's never had such issues before, and also said that metal nuts tend to corrode, and that brass nuts might be a better solution.
He also tried rubber washers (versus the plastic ones which come with the kits). Maybe the rubber washers helped, who knows.... In any case, i'm not sure if merely rubber washers are the best fix.
Any expert advice on this matter would be appreciated.
P.S. actually, what i'd have preferred most, would have been good-quality PVC nuts/washers so that if there's clogs in future, I myself would be able to unscrew, apply Turbo Snake or Drain King, then re-screw. Whereas the nuts/washers that came in this kit, seem to be the type of non-durable junk found in dollar stores. I mean, how much of a beating can plastic washers & threads hold up to?
RE: Help - new kitchen drains leak - see pic
Was it really a plumber, or some hack they assigned to do a 'simple' job?
It's obvious from the photo that little to no care was taken to 'dry fit' the components to ensure they are squarely installed one-to-the-other before being tightened. The rubber washers were needed only because of the crude installation.
As far as I can tell from the photo, the parts used should stand up to normal use, though not necessarily to a snake a plunger or to pressurized air or water drain clearing techniques.
With competent installation, you should be able to remove,clean and reinstall them as needed.
JMHO
Thanks so much for the input, randy. Can you please clarify to this layperson what you mean by "dry fit" and how you were able to tell they were not squarely installed?
It would be helpful to me if I could understand this better.
To answer your question, yes, actually he is a plumber who lives across the street (taught by his father).
Granted he may be amateur, but he's been doing plumbing for years in this area, and many people have been satisfied.
He had installed a complete sink and faucets and drains at my sister's house, and it's been running perfectly for years.
In past years he also installed my new water boiler as well as kitchen faucet. And there were no problems with those either.
dry fit = putting the parts together before gluing to see that they fit correctly together before final installation.
Had this been done, it should have been obvious that the left side was not correct. The horizontal pipes should be straight across, not at an angle.
Here is the simple solution..
And in regards to the guy at the hardware store who told you that you need metal nuts,,,,,Now you know why he is making minimum wage as a hardware store clerk instead of plumbing.
"dry fit = putting the parts together before gluing"
They are no glue joints in this setup, they are all slip joints.
Straight really matters for slip joints, and make sure there is a bevel washer under every nut with the flat side toward the nut.
"make sure there is a bevel washer under every nut with the flat side toward the nut."
Recently changed out my bathroom vanity, had to redo the drain pipes and nearly wept with frustration until I figured this out.
In this case the simple solution it to walk across the street, smile and kindly let him know it's still leaking.
BTW, the surprised response of "I never had such issues before" is just "profession exaggeration" that makes everybody feel better. Leaks after repairs actually can happen to anyone on occasion, which is why one should tests/inspect every joint before they leave. Using a small flashlight is helpful.
Dry fingers can detect leaks that the eye may not see. Rub the surface with a dry finger and then look to see if the finger has moisture.
"Rub the surface with a dry finger and then look to see if the finger has moisture."
A piece of TP works even better.
The slightest moisture shows.
Thank you SO much lazypup, brickeyee, busdriver, and everyone else for the clarifying pic, and the tips.
Re: the profession-exaggeration, homebound, I kinda suspected it (since I get that from not only servicemen, but also society at large, all the time). Thanks for validating that, since misery loves company ;)
In any case, I had done exactly that - in-person-summons... And he came last week and redid it though I'm not sure he followed all the steps listed in lazypup's pic.
So far so good. The floor of the cabinet seems bone dry, and the finger-test tested dry as well. What's TP? Couldn't find it on google images.
Toilet Paper
ah.. toiletpaper - thanks. Well I just tested it via PT as that was more handy than TP, and it was dry.
Any particular strategic areas that should be tested?
He had used a locking pliers to tighten everything, that's aside from the rubber washers at the strainers.
If in future it gets clogged again, can I easily detach the U-shaped pipe so as to insert my Turbo Snake into the pipe beyond which is connected to the metal piping? (a/k/a "trap adaptor) He seems to have clamped two bands surrounding the aforesaid metal piping. Those aren't so visible in the pic.
