Fri, Jun 22, 12 at 22:38
| My husband and I are retiring, and we have purchased a 1900 square foot home that has a Rinnai R-85 tankless heater powered by natural gas. We are rehabbing the bathrooms, because after removing the floor and wall tile in both bathrooms we discovered rotten floor joists. The crawl space of the house had sprayed foam insulation, so the rotten floor joists were not discovered until we gutted the bathrooms. We jacked up the walls and replaced the floor joists, and we have temporarily screwed down the subfloor, so we can remove it to work on the water and drain lines. The hall bath will have one lavatory sink with faucet, a small bath tub with tub filler, a fixed shower head, and a hand shower for bathing grandchildren, washing the dog, and rinsing the tub after cleaning. The master bathroom will have two lavatory sinks and two faucets, a shower only with a ceiling mounted 8 inch rain shower head and a hand shower on a slider bar. Should the supply water lines be 3/4 inch as advised in many of the threads? We will appreciate any advice, because we have no experience with a tankless water heater. I hope to hear from all of you! |
| Congratulations on your new purchase. As for the Rinnai, Rinnai makes a great product and while it can take care of a home with many people and more demand, it's even better for you and your husband because you will only be paying to heat the water you are actually using. Most concerns/complaints anyone have with a Rinnai can generally be tracked back to improper installation, most often being the sizing of the gas line- other than that, maybe once or twice a year we may get a call to 'flush the heat exchanger' (which for us has normally been due to construction locally getting more debris in the lines and getting sucked into the system, also clogging the filter, but I digress). As for the 3/4" lines, judging by the size of your home and the description you have 2, maybe 2-1/2 baths (?), either way, 3/4" coming into the house is perfectly fine. Remember you can only serve 2 fixtures on 1 1/2" line while you're doing your distribution and you'll be fine. =-) |
Return to the Plumbing Forum
