Wed, Jun 27, 12 at 19:25
| Last year installed a water softener with a Fleck 5600 valve.
Not seeing anything in the manual in regards to residential water pressure. Are there any rules of thumb of what the water pressure should be for proper backwash so that the resin won't foul/so that the water softener works most effieciently? Mine is set at 30-50. Is this too low? |
- Posted by justalurker (My Page) on Wed, Jun 27, 12 at 19:56
| Along with your softener you should have gotten an owner's manual, service manual, and/or literature. In case you didn't here they are... http://www.pentairwatertreatment.com/en-us/Products/ResidentialControl Valves/Fleck+5600.htm Pressure specs are... Working: 20 - 125 psi |
- Posted by lazypup (lazypup@yahoo.com) on Thu, Jun 28, 12 at 1:01
| you machine has a working rating of 20-125 however the plumbing codes mandate residential service pressures of 40-85psi so unless you have done something to alter your basic service pressure your machine is fine. |
- Posted by calhoontuna (My Page) on Thu, Jun 28, 12 at 7:35
| Thanks guys. Had the one manual -- which didn't specify water pressure -- but not the other, which did. |
Return to the Plumbing Forum
