Fri, Jun 29, 12 at 14:58
| Hi all:
I'll be running two lengths of PEX, maximum run 40ft. The end of the runs will end in a stud bay to connect to shut-off valves. Will leaving slack in the bay satisfy the expansion issue or does slack have to be spread over the length of the run?. Thank you |
- Posted by lazypup (lazypup@yahoo.com) on Fri, Jun 29, 12 at 16:04
| Slack is equal to 10% of the run and it should be evenly spread out. |
Return to the Plumbing Forum
