Sun, Jun 12, 11 at 10:59
| I have a sump pump that releases directly into my front yard. There is a slight slope going down. The pump usually releases every 10 to 15 minutes. I have begun digging a hole which at the moment is about a foot deep and 5ft by 3ft wide and nearly filled with water. I am interested in making a natural stone rain garden. Not finding much information concerning both in combination. I have clay soil so right now the water is not draining as fast as it should not sure how to handle this. The reason for this project is there was grass there originally that was always swamp like and not very pleasant to look at. Any help would be greatly appreciated. Thanks jjbjr |
| If you do not get the water far enough away from the sump pit it WILL end up back there. |
- Posted by dan_martyn (My Page) on Mon, Jun 13, 11 at 13:31
| jjbjr, You can get catch basins, underground piping and a pop-up at your local plumbing supply or big box. You can recess the catch basin in the ground (grate on top) just under the sump termination. extend the underground piping 30 to 50 feet away from the house and terminate piping with a pop-up. The water will be pumped into the catch basin and when the piping fills, the pop-up opens up releasing the water into the yard. This eliminates the water from getting back into the sump. Hope that helps, Dan |
Return to the Plumbing Forum
