| Hi, thanks for help in advance. I've looked, but haven't really found a similar question and it may be that it is a. a blonde one, or b. the answer is so obvious that I should be embarrassed to ask it (which is really see also a.)
The photo below is the sink wall for our tiny guest bath
This is the type of sink I want to install my preference is the 31" wide option but I can squeeze in the 37" wide version...
I have a couple of questions regarding the supply lines.
I think they need to be moved asthetically, but am not sure what it will cost at this point( i think there are only 3 to 4 drywall screws involved to get that down now) but then there is the rest of it... If we leave them in place should there be any problems with the water supply lines back to the sink if I order the flexible kind? Other than I really want them to be straight visually? It seems that the bottom of the "p trap will be mighty low to the floor. of course my equivalent of Eldon in "murphy brown" says "its better for me if its lower...
please let me know what you think... |
| The directions that comes with the sink should have the recommended locations for the pipes, if you leave them the way they are you are going to be pizzed off ever time you look at them, your choice, luck. |
Return to the Plumbing Forum
