Time to replace well-pump relay?
Posted by mcguirev10 (My Page) on
Thu, May 3, 12 at 23:50
I have a pretty run-of-the-mill SquareD Pumptrol 9013-FSG-2 2HP well pump relay that is about 7 years old. Tonight it stopped working while my wife was taking a shower. I went out to the utility room and pulled off the housing, it looked fine and there were no obstructions, but relays being what they are, I tapped it with the handle of a screwdriver. Sure enough, it clicked on and appears to have resumed working, switching on and off as needed to fill the pressure tank.
However, the contacts look a little blackened and worn. A few years back we had a problem for a short time with it flicking on and off rapidly caused by a loose wire, and I had always wondered if that shortened its life.
They're cheap, am I better off just replacing it, or would it just be a waste of money? If the URL below comes through, they look a lot more like the "used" image on the right than the "new" image on the left...
http://en.wikipedia.org/wiki/File:Contacts_-_new_and_used.jpg
RE: Time to replace well-pump relay?
Replace it.
Not worth messing around with it.
Overheated contacts will shorten their life.
