| We have flushometer toilets in our 1921 co-op apartment.
We're going to have to replace them because NYC is mandating a backflow inhibitor which will cut the water pressure a lot, and they won't work. (Or, if they do work, they'll have much too negative an effect on the apartments above us.) Other alternatives are to install costly pressure pumps and holding tanks, etc. Which is not really a desirable step. Replacing the toilet is going to be problematic for several reasons:
So I got to wondering--can we just mount a tank above the toilet on the wall? You can buy the high tank by itself; can we simply attach it to the flushometer toilet? And if so, can we offset the tank by a foot or so, or does it have to be directly below? |
- Posted by lazypup (lazypup@yahoo.com) on Sat, May 12, 12 at 4:05
| First of all, a backflow preventer does not alter the pressure and it would have no impact on your neighbors system pressure. You can not install a high tank. Based upon the age of your bowl it requires either 5gpf or possibly 3.5gpf, but code now mandates that you cannot install anything bigger than 1.6gpf, which would not be enough water to flush your bowl. Any attempt to modify your bowl would be classified as "New Work" which means you would be required to install a 1.6gpf watercloset. |
- Posted by talley_sue_nyc (My Page) on Wed, May 16, 12 at 21:17
| thanks, Lazypup. I was hoping that 1.6 would be enough to flush it; there are high tanks that are 1.6 gallons. Rats! So it's the design of the bowl itself that requires us to have that much water? |
Return to the Plumbing Forum
