Mon, May 16, 11 at 14:10
| Hi everyone,
I live in Central Florida which is known to have hard water. We would like to add a water softner to our house. The measured hardness is between 15 and 20 so I think we are a good candidate. We have 3 people in the house with 4 bathrooms. My plan is to purchase a Flex 7000 with 80,000 grain capacity.
any comments on fleck. Where is a good place to look for someone to install. The house previously had a water softner and the loop is already in place. thank you |
| You really don't need that large a capacity system. A 60k system will be more than adequate for your needs. If you believe you need that much capacity a Fleck 9100 90k twin tank would be much more efficient. Potassium is not as efficient as sodium so it takes 25% more KCL to regenerate the same amount of resin. You can contact Nelsen Corp in Florida and they can recommend a dealer in your area. Here is the info. Nelsen Corporation 5120 E Adamo Dr. Suite F Tampa, FL 33619 Ph: 866-712-6796 |
Return to the Plumbing Forum
