| I have a current issue with my downstairs shower where my pipes want to "rattle" if I dont reach the temperature i want prior to pulling the shower knob in our tub. Basically, if i start the flow of water then immediately full the shower knob, i get major rattle. Lately, it's been occuring even when I do get my temperature right before pulling the knob. Sometimes I'm able to end the rattle by turning towards more hot or cold water, then adjusting to the temperature i'd like, but regardless, it's very annoying and I feel it rattles so hard at times that it may damage the pipes.
I feel i need to note that i found this post from an earlier problem on this site and thought it was very informative: Posted by zl700 (My Page) on Tue, May 13, 08 at 9:23
Do I need to adjust the balancing spool (or replace). I'm not sure if there are adjustable valves in our crawl for the hot and cold water lines in our shower, so that isnt an option. I do want to note that my hot water heater is upstairs and the problem is downstairs...maybe gravity is causing excessive pressure in the HW line? I know it isnt "water hammer"....i feel it's mainly due to pressure differences through a restricted space. Anyway, i'm usually pretty good in figuring this stuff out, but any help would be great. Thanks! |
| Not a plumber, but one easy solution may be to tie in a pipe into the cold water line so it goes vertically up the wall cavity. This way any water in the line will rise into this empty line and become in effect shock absorber for any rattling caused by air formation. |
Return to the Plumbing Forum
