Fri, May 6, 11 at 9:29
| our well pump motors shaft does not turn freely. i contacted the mfgr and was told it was a chinese motor and no parts are available. the bearings are sealed. does anyone know if it's possible to find replacement bearings to repair this? |
| Many bearings are 'standard' items available from bearing supply houses. If not by application or part number on the bearing then by dimension. The problem is that you are likely to need to remove the bearing and take it to a bearing supplier for them to match or measure. It might be worth just pulling up the pump, installing a new pump, and THEN seeing if repairing the old one is practical. |
Return to the Plumbing Forum
