1/2 inch brass pipe
Posted by dadgardens (My Page) on
Sat, May 5, 12 at 1:48
The supply line for one of my toilets is 1/2' brass. I need a new flush valve, and a supply cut off.
Is there an an easy way to install a shut-off(cut-off) valve?
Standard copper parts are too small or too large. Brass has become a pain...
Yes, it is an old house (1750's). I want/need to find a way to
add a cut off valve. I do not want to become a machinest, cutting parts to fit!
I will consider any suggestion - local hardware store had none.
Dad
RE: 1/2 inch brass pipe
Brass pipe is the same size as iron pipe. The threads on the end of the brass pipe are 1/2" MIP threads 1/2" male iron pipe).
All you need is a 1/2" MIP x 3/8 compression angle stop valve and some pipe dope or red teflon tape.
the 1/2"fip x 3/8compression angle stop valve can be found anywhere that they sell the valves.
Thank you very much! I mean it!
