oil filter connection leaking
Posted by foodonastump (My Page) on
Sun, Apr 1, 12 at 18:32
The fitting on the "out" side of my oil burner's filter (westwood) has had a slow drip since day one. No luck getting the installer to take care of it so I figured I'd give it a shot on my own before calling someone else for service. Can/should any type of sealant be used on the threads?
While I'm at it, anything else I need to know beyond common sense like turn off the oil valve and how to prime the burner which I have to do every time I run out of oil? :)
RE: oil filter connection leaking
"Can/should any type of sealant be used on the threads? "
That depends on what type of connection was used.
Oil lines are often flare connections, so try giving the nut a turn.
Thanks. The copper tubing connects to a brass fitting, and then the brass fitting screws into the cast iron top. Here's a picture, maybe not the exact model, but it's where the brass screws into the red CI that's leaking.
Any pipe dope rated for WOG (water, oil, gas).
That's what I needed to know - Thanks!!!
