No drain
Posted by misty_morn (My Page) on
Wed, Apr 21, 10 at 18:15
The water pipes that were to go to the beverage center were installed (by mistake) into the island. They are across the room from one another. Before I got to the site of the construction, the cement floors with radiant heat were poured and set.
Needless to say, I am very disappointed. My plan was to place the coffee maker, margarita machine, sodas (in small cooler), etc in this area. The plumber has run a water line to the beverage counter/center. But there is no drain. I am still debating about putting a faucet in this area. If not a sink, I've also considered a large metal bowl to catch overflow from faucet, ice, etc. Crazy?? Does anyone have any other ideas, suggestions? Please---
Thanks in advance
RE: No drain
Code does not permit installing a faucet unless you have an approved drain.
RE: No drain
I'll go looking to see if potfillers are therefore not allowed by "Code".
Many taps for filtered water are low-flow.
Many are made with springs so the handle cannot stay on.
You can see them on the web by searching for "glass fillers"
The lack of a drain is still a big problem. Cleanup functions would require you to go somewhere else to change the water in a pail. (think coffee grinds!)
