Thu, Apr 21, 11 at 17:21
| I just read a bunch of posts basically saying "few states other than CA require an air gap anymore." I also skimmed one that I think said that IRC codes don't require an air gap, but UCC codes do. Except that I closed that tab and can't find it again!
I live in PA, which uses UCC code, but I can't download the actual code itself to look it up. Does anyone know if PA requires an air gap, or if UCC code does? Thank you! |
- Posted by ramona1976 (My Page) on Sun, May 1, 11 at 18:16
| I think Pennsylvania uses IPC. IPC 802.1.6 allows connecting through an air gap or discharge into a wye-branch fitting on the tailpiece of the kitchen sink, or the dishwasher connection of a food waste grinder. If you don't use an air gap the dishwasher waste line has to loop up and be fastened to the underside of the counter. |
Here is a link that might be useful: Pennsylvania Plumbing Code
Return to the Plumbing Forum
