Thu, Apr 19, 12 at 12:31
| I recently had a Kinetico 2040s installed and they didn't run a line from the overflow on the salt tank to the floor drain.
I assume that I should so can anyone tell me what size and type of hose to use? |
- Posted by lazypup (lazypup@yahoo.com) on Thu, Apr 19, 12 at 12:43
| The line should be a full bore line equal to the size of the discharge port on the tank. On the termination end the line MUST terminate a minimum of two times the line diameter above the flood level rim or the floor drain. |
- Posted by andy_c (awc222@yahoo.com) on Thu, Apr 19, 12 at 21:13
| use 1/2" line. |
Return to the Plumbing Forum
