| I bought a battery backup sump pump and need to know how to proceed on the check valve configuration. The current A/C pump has a check valve, but it's about 5 feet off the floor and the discharge line is bracketed to the wall. Discharge comes out of pit about 2 feet above floor before 90 deg. bend takes it to the wall. About another 3 feet up is the check valve.
I understand that if the main pump did not have a check valve prior to installing the backup, one needs to be put in for both pumps and the connection of the two discharge lines occurs above the check valves. So I see 3 options, please let me know what is best, unacceptable, or offer another.
| OK, option 1 is not really an option. I guess I would prefer option 2 as long as there is no harm in having an extra check valve in the mix. |
Return to the Plumbing Forum
