| Sorry if this is too long a post; I've been told that there are both professional
plumbers and advanced do it yourselfers who particiapate in the forums and they expect the information to be as complete as possible, especially from those not experienced in plumbing like myself. So thats why its longer than it probably should be, since I don't know how little or how much info to provide. ===================================================================== SUMMARY I have a water leak in a pipe or connector at or near the water meter at the street, probably on my side.
a. if its something that might be fixed at the site of the leak without needing to do a complete replacement of the
(I don't want to do a complete replacement for financial reasons and that
b. if it just might be at a place that is responsibility of the water department. c. if it can't be fixed at the spot of the leak and does need complete replacement, suggestions on how to
d. what the piece of pipe or connector where the leak is, is called.
PICTURE AND VIDEOS INFORMATION Please refer to the pictures and videos I posted at the picasaweb photo sharing site: https://picasaweb.google.com/101402405215792548679?authkey=Gv1sRgCO_p0 eio2ITeSg At the site, you can do the following: a. click on name of this album "water meter leak" and are taken to that page with the photos/videos. b. click on each photo to view or you can do a slideshow and within it, can set
c. The last 2 thumbnails on that page of pictures, the ones with black borders, are videos.
d. In the 2 videos, about halfway thru, it starts to look blurred; this is just me
e. I took from several views and zooms, also took videos to show I hope the flow of
f. The parts that show the water meter street side are just for your reference in context
===================================================================== BACKGROUND INFORMATION AND OBSERVATIONS 1. There is a leak that seems to be only at or near the water meter, on my side. The water meter is attached to a pipe that goes a few inches and then there seems to be
This continues under the edge of the meter box, and I guess either it connects to the first of the
a. I can see the water coming into and filling up the water meter box from under the edge of the meter box,
b. My friend who knows just a bit about plumbing, felt this piece of pipe as it goes under the edge of the wall of the
c. I bailed the water out of the meter box in order to take the pictures.
2. In the pictures, its that part right under the edge of the meter box, on my side, where
3. The water pressure and flow into house is still ok, though for sure the water
4. I realize the leak might be perhaps also further up towards the house, since
5. The leak seems to be on my side, although its not completely clear yet, that is, a. water department says its responsibilites are:
---> I don't know if the outlet side coupling (see pictures) is where the leak is or
b. I have not had them out yet as afraid that even turning off the valve at the meter might put
And also afraid they might view the soggy area as a leak in which they will want/need to
6. I don't know if a car or truck going over the meter box cover might have borne down into
That is, with a curved sidewalk that makes it easy for a vehicle to come up on the curb, and with
7. The driveway curves around - it starts straight from street then curves to the left to the
8. For now water the pressure and flow in house is ok;
9. We are older and my wife has medical problems, and I have been laid off for
And since the house will be torn down and replaced after us, there is no value added to the house
10. I am guessing the pipe is galvanized, and am guessing its old, though still don't know if
But I don't know for sure if it is galvanized, since can only see in the meter box itself - see the pictures
House itself is from the 1950s, but don't know if any replacement was ever done of pipe to house. Am hoping here to see if there is a clue in the photos that might indicate the rest of the pipe
11. I have some questions to ask for your comments or advice on below, based on the info in this section and
================================================================ QUESTIONS BASED ON THE INFORMATION ABOVE AND THE PICTURES/VIDEOS 1. From the photos, what is the piece of pipe called that goes under the water meter box wall on my side -- is it part of the piece that connects to the meter itself OR is it some separate coupling or other kind of connector that connects to piece that goes
OR is it the beginning of some long run of pipe towards the house ? That is, in the pictures, I see the meter on my side is connected to a piece, and then after an inch or two,
Thats supposedly where the leak is and thats the part am trying to find out what it is. Or perhaps its all one piece from where it connects to meter and onward under
a. Is this visible piece(s) galvanized ? b. and if so, does it give any clue that the rest of the piping to the house is galvanized) ? c. Is the connection to meter on my side that is visible in pictures a typical connection ? 2. Assuming the leak is really at the place where it goes under the edge of the meter box --
a. the water department says its responsibilites are:
---> Could the place where the leak appears to be be viewed as part of the outlet side coupling ?
The only soggy area I see is one in about a 2 foot square at and near the meter
But am wondering, if this was the case, would there also be some soggy areas
---> Based on above info, does it seem that the leak is just at that piece of pipe location noted above at
4. Do the pictures/videos and info above give any clue that a spot fix might be doable ? if the leak is at/near the piece in the photos that goes under the edge of the meter box)
I realize that just in having the pipe and box dug up, that it could move other pipes that might
And I realize that the pictures/video show a very small part and only up to where it goes under the edge of
5. If a spot fix might be done, and if it is galvanized pipe, can a fix be done right at the part thats
And in any case, can there be a problem in digging under the meter box, or taking it out if needed, to do the
6. Maybe trucks going over the water meter box cover (which has happenend quite a bit) might have borne down into
Does it look like that might have happenned from the pictures ? 7. Galvanized pipe repair problems in general a. is it that with older galvanized pipe, versus copper or pvc, that in touching some piece of it or moving it as part
b. For fixing leaks in galvanized pipe, do they need to dig up and take out full lengths of it from one connection to
(I realize that just in finding where some actual leak might be, that digging has to occur)
I realize from a textbook view, that probably many would say the entire line
And since the house will not be bought again, but will be torn down and new one
NOTE - the driveway curves around - it starts straight from street then curves to the left to the
a. given that the driveway is in the way, what might be the least cost method, ie trenchless vs digging up
b. can pvc be used vs copper ? I still have to find out if its legal here to have pvc used instead
c. would rerouting the pipe from meter to house be better and less expensive than digging up old pipe and
d. I read there also is the kind of repiping where they use epoxy or other sprays to fix existing pipe
e. do they ever route some temporary piping from water main to house shutoff valve while they are doing the work
f. am guessing the cost of the complete replacement would be a lot more than a spot fix,
g. I think that for a complete replacement, not sure if for a spot fix, that inspections and permits need to
9. What other things should I be considering and asking about related getting this specific leak fixed ? I'm going a bit crazy with all these new words and vocabulary and the stress
10. Any ideas on the right questions and words to use in talking with the plumbers or repipers so I can ask
11. Also, I am concerned that with whatever repair is made, especially if
The flow and pressure in house now is just fine. ---> What kind of things should I say to those doing the work to let them know about
12. About asking the water department to come out and take a look to see if it might be on their side and
I asked the water department that, if they came out, would they
They said that if the leak was very large and might damage property of others, they would
They replied that if I was home, and asked them not to turn if off, they would not,
---> Question - in your experince, do you think they will turn off the water if they see any kind of leak on my
---> Question - since it seems the leak is on my side, but very close to and
Or if indeed it might be part of their own responsibilities ? I just don't know if who is sent out are just those that turn water on and off and/or read meters
If not, does not seem worth having them come out now since
===> I realize the pictures might not show enough information to know if a spot kind of fix can be
And realize that once digging might start, that it could reveal or cause further worn out pipe or causing
(vs needing to do a complete repiping from the street to the house and under the driveway which
But in any case, I'd appreciate your feedback to these questions or any other feedback you might have. ===> Please let me know if you need more information; I tried to take a variety of pictures
And again, I apologize for the length of this, but felt I should provide you complete information. Thanks for your help. |
- Posted by bus_driver (My Page) on Mon, Mar 5, 12 at 18:36
| Most meters have a little triangular-shaped spinner visible through the window. The tiniest flow will cause this spinner to rotate. Shut off all the faucets in your house so that there is NO water being drawn. Then look at the spinner. If it is not moving, the leak is on the water supplier side of the meter. If it is moving. the leak is on YOUR side of the meter and is costing you money. Sometimes it is as simple as the connection of the pipe to the meter needing to be tightened. Don't try it yourself. |
| bus driver - yes, the leak seen in the pictures and video is registering on the meter, and is costing me money for sure, but am trying to get idea, from pics and description, if it is perhaps as you mention a connection needing to be tightened vs a leak in pipe that might require bigger repairs. ---> When you look at the pictures, can you tell what the type of piece is that goes from the meter on my side to the exit of the meter box on my side -- that is, it starts at meter outlet connection and then there is a raised and rust colored area of it, that then goes under the meter box ? its right under the part of that as it exits the meter box (see above post for more description of this) thanks for your reply and comments, and no, I will not try any of this myself. |
- Posted by bus_driver (My Page) on Tue, Mar 6, 12 at 9:24
| I did not have time to review all of your post. If you are satisfied that the leak is on your side of the meter and that you are not prepared to do the repair, the choices appear to be few. 1. Call someone who is qualified to do the repair. 2. Do nothing and pay for the water bill as it happens to be. 3. Have the water service shut off to stop the leak and avoid any expense associated with it. |
- Posted by hollysprings (My Page) on Tue, Mar 6, 12 at 13:12
| Old galvanized pipes have a finite lifespan. If you repair this leak, you have a good chance of it developing another leak in another location. The only good solution is a complete pipe replacement. The major expense of a pipe replacement will involve the digging of the trench from the meter to the house. This is an area where a DIYer can save some money. Have the utilities companies come out and mark the location of the pipe and any other utilities going to the home. Then you can choose a route parallel to the current pipe but just far enough away from it that you aren't disturbing it. You can rent a trencher (Maybe $200) and hand dig the larger access points at the meter and house. Then you can call a plumber to lay the pipe and make the connections. If you are not physically capable of doing this, then do you have any family or friends that would be? Church group? Scout troop? There are usually community resources that can help you to figure out what you can do here. The worst thing you can do is to ignore the leak. |
| "Old galvanized pipes have a finite lifespan. " Usually around 30 years. If they are past that start thinking about replacement, and a buried galvanized pipe that made it 30 years would be VERY good luck. The only leak that is usually the water supplier is the joint between the meter itself and the valve body it mounts to (if they have one). Anything else that leaks water on the outlet side is your problem. Older installs may have a valve body, newer setups rarely do.
Return to the Plumbing Forum
