Thu, Mar 31, 11 at 16:36
| Thanks for readings! I'm new at this, which do you think is better?
Side note: We have to get a propane unit first then when we can open the street in 2 years convert to NG. The NG conversion kit on the Rinnai is $400. The conversion kit on the Noritz is $170 which is more normal. That being said, the Noritz seems to have a much better flow rate than the Rinnai, however the Riannai is a little more efficent. I'm leaning to the Nortiz. Do you guys have any thoughts? |
| Both good units. Flow rate is actually closer than you think, Rinnai has a habit of showing 30 degree rise in their spec while all others show 35 degrees, making Rinnai appear better. Although 1% more in efficiency means a minute more in flow rise. The big difference between the two is the Noritz is PVC vented while the Rinnai is their brand Polypropylene which is expensive. |
Return to the Plumbing Forum
