Replace a working, old water heater?
Posted by mrpandy (My Page) on
Tue, Mar 15, 11 at 3:26
My electric water heater (AO Smith) is original to the house, which was built in 1987. It works fine and I have never done anything to it execept drain it twice (to move it).
Since it is 24 years old, should I replace it now to avoid an emergency repair that is probably coming?
I will be replacing it with just a standard, no frills electric like the GEs at Home Depot. Are the new water heaters that much more efficient that I would notice the difference in my electric bill?
RE: Replace a working, old water heater?
"If it ain't broke don't fix it"
Electric water heaters have the same efficiency as they always did; the difference in modern heaters is better insulation to reduce standby loss. All things considered, your utility bill probably won't change much.
Were I you, I would pull the anode and make a determination from its remainder what life may be left. Sounds like your water is ideal.
If you haven't updated the inlet/outlet piping to prevent heat loss, doing so will yield savings with any heater.
My heater is 26 years old (electric). I am in the process of replacing it with a Rheem Marathon. I chose to do it on my schedule. ...not Christmas Eve which is when mine will fail.
How much damage will result when the tank rusts through and leaks?
It is on borrowed time, but if it is in an unfinished basement I would leave it but check it over VERY carefully at least once a month looking for leaks.
You may get a slightly better price on install if it is not an emergency also.
