Wed, Feb 2, 11 at 23:02
| Hi
I just purchased a Zoeller 507 back up sump & need to purchase a 12V Deep Cycle battery http://www.ecrater.com/p/7278528/zoeller-507-basement-sentry-12-volt-d c ANy suggestions? Thank you! |
| I've found that using a regular automobile battery, (84 amp-hour), does well when power outages don't last more than a couple of days. YMMV. Deep-cycle batteries, though, can be found at most marine supply stores. |
| Car batteries are optimized to provide the high current needed to operate the starter in a car. The cold craning amps are delivered for only about 30 seconds before giving the battery a chance to recover. Deep cycle batteries are designed to deliver rated amp-hours at lower discharge rates, and not short out the plates as the enlarge from discharging. |
- Posted by justalurker (My Page) on Thu, Feb 3, 11 at 18:17
| The Optima AGM batteries are available in deep cycle and are well thought of... http://www.optimabatteries.com/optima_products/yellowtop/index.php |
| Thank you all! |
Return to the Plumbing Forum
