- Posted by justalurker (My Page) on Sun, Feb 13, 11 at 21:46
| Seen it many times... @ 21gpg hardness the spotting you see is the sodium (or potassium) that is ion exchanged into the hard water (to make it soft) precipitating out of solution onto surfaces where you leave the water to evaporate. Sodium (or potassium) ions are exchanged into the raw water at roughly 2 to 1 to remove hardness and manganese ions and iron making the water soft. Along with that, if your softener is undersized for peak demand, as most unfortunately are, hard water leaks through at max SFR and can add to the spotting. Salt spots are best managed by wiping down the wet surfaces with RO water before the spots dry. Hardness spotting can be dealt with by wiping down the surfaces with a highly diluted white vinegar solution before the spots dry. If you let the spots dry after a time they will etch the surface and the finish will suffer which it appears is where you are now. If you haven't been using Iron-Out (or a similar product) routinely then the resin may not be regenerating at it's best capacity. How often does your softener regenerate? How many people in the house? How many bathrooms? Any high use appliances like a Jacuzzi? |
- Posted by mrmichaeljmoore (My Page) on Sun, Feb 13, 11 at 22:43
| Thanks for the reply.... To answer your questions: 2. My softener regenerates as needed based upon the settings and usage. But, it is set to regenerate every 10 days if I don't reach the predetermined limit. It is a 48K unit. 3. 2 adults, 1 toddler, 1 infant 4. 2 Full Bathrooms 5. No high use appliances In speaking with the company I purchased the softener from (and the local lab that did the water testing), they said that if the spots were sodium, they would wipe away with just a damp cloth. Not true? Also, you mentioned wiping down the fixtures after each use, either with RO water for salt or vinegar for hardness..... Are there any other solutions to this problem? thanks. |
- Posted by justalurker (My Page) on Sun, Feb 13, 11 at 23:25
| 1. Yes, you have iron. Only .05 ppm but you have iron. Once a month dissolve a 1/4 cup of Iron Out or Super Iron Out (most box stores carry it) in a couple gallons of warm water and pour it down the brine well (4" tube where the float lives) in the brine tank and do a manual regeneration. Don't spill it or get it in your eyes. 2. Setup correctly with your water conditions the softener should regenerate every 6 or 7 days with a calendar override set at 8 days. Do you know what salt dose and hardness removal capacity the softener is set at? Salt spots will wipe away with a damp cloth but you'll only be spreading the salt water not removing it... right? If you have an RO then RO water works wonders getting minerals back into solution and removing them from a surface. With your hardness and TDS I hope you have a quality RO under the kitchen sink for drinking, cooking, and ice cubes but if not, then distilled water works well also. High hardness water presents this problem and the solution (no pun intended) is preventative maintenance in the form of timely cleanup so the sodium in the water doesn't etch the chrome and glass. Don't wash your car with your soft water and then let it air dry... spot city. |
- Posted by mrmichaeljmoore (My Page) on Sun, Feb 13, 11 at 23:45
| My softener setup is as follows: The salt dose is set at 9lbs/ft. I am pretty sure that is the default setting. No, I don't have an RO. So, in order to save my fixtures I need to wipe the chrome and glass dry after each shower? Not to sound ungrateful, but what a pain. I do squeegee the shower door glass, but I guess I'll have to keep a towel handy so I can wipe down the chrome now too.....ugh... What about the effects on the tile/grout? Any issues there I should be aware of? On another message board, someone suggested silica as my problem.....any chance it could be that? thanks. |
- Posted by justalurker (My Page) on Mon, Feb 14, 11 at 0:13
| @ 21 gpg I can understand that you don't like the taste of the water. you should REALLY consider an RO. Merely wiping the the chrome or squeegeeing the glass will still leave sodium on the surface. Since RO water and distilled water have been stripped of minerals they are the universal solvent and will lift minerals from the surface an that is your goal... to remove the sodium. Your softener seller should have taken the time to explain the conditions of your water, what they proposed as treatment and what you should expect but based on the setting of your softener they don't know much about how to program a softener for efficient operation so I'm not surprised they didn't. A 1.5 cu ft softener at max salt dose of 15 lbs/cu ft (22.5 lbs of salt for 1.5 cu ft resin) only yields 45,000 and will never see 48,000 Is your salt setting 9 lbs/cu ft or 9 lbs TOTAL salt dose? It makes a big difference. There is a possibility that the programming in the softener control valve is not allowing an adequate time for rinse after brining but then the water would really taste salty... like sea water. Living with really hard water involves a little maintenance and so does living with a well and living in the country. If it's any consolation there are people living with far harder water than you have. No, it is not silica. Your pictures are textbook illustrations of evaporated sodium and/or hardness. |
- Posted by justalurker (My Page) on Mon, Feb 14, 11 at 9:17
| You might try switching over to KCl (potassium chloride) as a regenerant. It cost a lot more than NaCl but it is worth a try. Around here Costco, WalMart, Sam's Club, and Home Depot carry it. costs around $14- $16 a 40 lb bag but HD gouges us for $24. You can just let your salt run low (NOT RUN OUT) and add the KCl on top. Only add as much as you need to cover the water. Don't fill the brine tank up... a good practice in any case. Normally the salt dose would change with the change to KCl and your hardness but your salt dose is high anyway so we can leave that alone for the time being. |
- Posted by aliceinwonderland_id (My Page) on Mon, Feb 14, 11 at 11:09
| The hardness of your untreated water does not account for the severe water-spotting you are experiencing. Neither is your TDS terribly high. Sodium spots on faucets should be relatively easy to remove with vinegar and a cloth. The difficulty you are having removing the spots suggests sodium alone is not the culprit, which leaves you with some potential problems: 1) Your softener may be undersized, allowing hardness to blow through under high-flow conditions, 2) You softener may be set incorrectly, not regenerating often enough, incorrect salt dosage, or have some mechanical problem affecting the brine portion of regeneration, 3)You may, indeed, have high silica in your water. Both silica and hard water spots can be difficult to remove mechanically. If the spots are partially from hard water, acid cleaners, such as vinegar, CLR or Lime-Away will work. Silica spots, however, are acid-based so acidic cleaners will have virtually no effect. You might try scrubbing with a paste of baking soda, or use a strong alkaline cleaner and see if that works. Once you have the faucets clean, you may wish to apply a sealant, such as those used to cause water to sheet from glass rather than beading up, to make it more difficult for any minerals to stick. |
- Posted by mrmichaeljmoore (My Page) on Mon, Feb 14, 11 at 12:48
| justalurker: I checked the softener manual. The salt dose is default set at 9 pounds per ft cubed. I will have to double check the estimated capacity tonight when I get home. I think it said 48KG, but I will confirm tonight. Unfortunatley, the KCl is rather expensive around here too. I'll have to keep an eye out to see if I can find it cheap. But I'm not confident..... I gotta be honest....I had no idea that the high sodium is so corrosive. That's really frustrating to trade one corrosive (hardness) for another (sodium). Don't get me wrong, I hate showering in hard water....much much prefer the soft water for showering. But, you can understand my frustrations....especially when I thought I was doing everything by the book (sediment filter, softener, csrbon filter) to give my family and home good water..... Any suggestions on what to use to clean the sodium spots? I may try that Mr.Clean Magic Eraser..... Are there any ways to tweak my softerner to get 0 hardness (or close to 0) but get better salt effciency or reduce the salt usage, there by reducing sodium in the treated water? Aliceinwonderland: Not sure if this helps, but my softener unit is the following: Do you think the softener is undersized? thanks to both of you for the help. |
- Posted by justalurker (My Page) on Mon, Feb 14, 11 at 13:28
| Soft water is preferable to hard water. Hardness (calcium) does damage to plumbing, appliances, and fixtures. Your complaint is a cosmetic consideration and absolutely valid. I respect Alice but disagree with him on this subject... as hardness goes up the amount of sodium in the water increases and can (and does) manifest itself as more severe water spotting. The amount off sodium has not increased as to be a health consideration (unless one is on a no salt diet) but does cause cosmetic problems. Once sodium has etched a chrome surface there is no easy retreat back to a mirror finish. The etching must be removed and that means a loss of chrome to some degree... like compounding or polishing out scratches from your car's paint. From the info you have provided I believe your softener is not set up to operate efficiently. It does appear that a 1.5 cu ft softener is slightly undersized for your family of four and as the kid get bigger it will regenerate more often. If you want to reprogram your softener for most efficient operation set it as follows... hardness 22 Should regenerate every 6 days or so and use less salt. If your softener is operating correctly (doesn't have a problem) this should make a difference. Let us know how it goes. If you don't have the complete 762 manual copy and paste this URL... http://www.pentairwatertreatment.com/PentairFiles/Pentair Water Tr eatment/Manuals/742 762 Owners Manual 3000440.pdf
- Posted by aliceinwonderland_id (My Page) on Mon, Feb 14, 11 at 16:26
| Yes, of course sodium content of softened water is higher with harder water. And sodium will cause spotting. Agreed. The amount of spotting, however, is excessive for it to be due only to sodium at the concentrations in this case (unless, no one ever wipes the faucets?). If you are curious, you can determine whether your softener operates well under various conditions. Takes samples: 1)Shortly after regen, 2) shortly before regen, 3) During high water use, 4) During very low water use. |
- Posted by justalurker (My Page) on Mon, Feb 14, 11 at 17:00
| Alice, Looking at the 762 manual it doesn't seem that the cycle times are variable but rather determined by an algorithm based on hardness, resin volume, and salt dose. Crunching the #s it looks like the OP's softener isn't setup right. I think if he resets the softener as I've suggested above it will mitigate or eliminate his over spotting problem. IMO, he will still have to wipe down the chrome and glass and using either RO or distilled water really works very well to migrate minerals like sodium off those surfaces, All our suggestions don't preclude that the softener has an actual problem or less resin than the 1.5 cubes it should have but we can't see that over the net. Any brine pickup problem would result in less salt in the resin not more. If the 762 went wacky I guess it could be introducing too much water for brine but I think the OP would have noticed that. Now the OP has some things to try that won't cost him any or little money. MM, Check to make sure that the drain line from the control valve is not pinched, collapsed, or restricted in any way. If it is, the rinse cycle won't remove all the salt from the resin. Your seller should have used the semi rigid milky white PE (polyethylene) tubing for the drain line and not the clear vinyl soft stuff. There should be a code required airgap where the drain line meets the drain. Make sure that airgap is working properly. |
- Posted by aliceinwonderland_id (My Page) on Mon, Feb 14, 11 at 17:59
| Since the amount of sodium in the treated water is determined by the amount of hardness in the water and the effectiveness of the exchange process, making the softener more salt-efficient will improve the operating cost but will not decrease spotting. A brine pick-up problem would result in less-than-complete regeneration, which would result in more hardness breakthrough, increasing spotting. |
- Posted by justalurker (My Page) on Mon, Feb 14, 11 at 18:07
| And a more efficient use of salt would mitigate the inability to control the cycle times and might(?) provide a more effective rinse. There is no downside to setting up the softener to operate efficiently and not waste salt and water and to not go longer between regenerations than optimum for longest resin life regardless of whether it solves the spotting problem. We really have to wait for the OP to do some stuff but the more I think about it the more I think the over spotting might be drain line related. |
- Posted by justalurker (My Page) on Mon, Feb 14, 11 at 20:48
| I am in error... re-reading the 762 manual it does seem there is some control over some cycle times but for now MM has other things to try. |
- Posted by mrmichaeljmoore (My Page) on Wed, Feb 16, 11 at 11:42
| I dropped off a water sample to my local lab for testing. They are going to test for TDS and Silica. They are also going to test for Bacteria (I shocked my well over the summer, just want to be sure no bacteria is present). I will post the results when I get them from the lab. I cleaned the Basement Shower chrome last night. RE: the Drain line and the air gap. RE: adjusting the water softener settings Aliceinwonderland:
What is the effect of the sodium/spotting on the ceramic tile? Will it ruin the glaze? Dull the tile? thanks. |
- Posted by aliceinwonderland_id (My Page) on Wed, Feb 16, 11 at 12:12
| Reducing the salt used during regeneration makes your softener more salt efficient, but also provides a slightly less complete regeneration. This reduces the amount of time your softener can run before needing to be regenerated. The calendar override is very important. 10 days is too long. As your softener is in normal operation, water is flowing down through the resin bed. This slowly compacts the bed over time, increasing pressure on the resin beads. This pressure, over time, weakens and then breaks the beads. The longer you leave it without backwashing (which cleans out debris and re-fluffs [nice techie term there] the bed) the greater the damage. For home use I recommend no more than 7 days between regens. However, eight is probably okay. Ideally, softeners would be equipped with a control system that would allow a backwash without a regeneration for cases where hardness is not terribly high, but most don't so you have to make a trade-off between extra salt usage from more frequent regeneration and extra resin bead damage from less frequent regenerations. I was being tongue in cheek when I suggest no one was wiping the faucet. It would really be a huge pain to have to dry the shower after every use. It might, however, be worthwhile to get a bottle of the stuff you can spray in the shower and use it after your showers - it does help and, although a bit of a hassle, is easier than scrubbing and scraping. As to the tile, the spotting could eventually give it a dull appearance, but will take much longer to cause any damage compare to the chrome. |
- Posted by justalurker (My Page) on Wed, Feb 16, 11 at 12:15
| RE: the Drain line and the air gap. That will do. Make sure the tubing is not kinked. RE: adjusting the water softener settings. By lowering the salt dose the hardness removal capacity (called the "K") of the (set) volume of resin lowers also and there will be less gallons shown between regenerations. " I don't think I ever reach the 2000 gallon number; I think i usually hit the current 10 day calendar override before regenerating. See my confusion?". You are confused because you don't know and I'm trying to tell you what to do to set up your softener to operate efficiently and cut down on the amount of salt you use and to stop wasting your soft water. Your softener is set up to use too much salt which will provide too many gallons between the optimum regeneration intervals so you never use all the softened water your 1.5 cubes of resin could provide set up the way it is now. By lowering the K of the 1.5 cubes of resin by lowering the salt dose there will be fewer gallons of soft water treated and you will use most all of it between the optimal regeneration interval of 6-7 days. In other words... using more salt to get more gallons of soft water and then not using all the soft water but going longer between regenerations is wasting salt and water, but using less salt and getting less gallons of soft water and using most all of it between more frequent regeneration is actually more water and salt efficient. You may not understand but if you do the math over a year you'll find you use less salt and that saves you money. |
- Posted by justalurker (My Page) on Wed, Feb 16, 11 at 15:12
| The algorithm in the 762 will lower the hardness removal capacity of the 1.5 cu ft of resin when it sees the change to a lower salt dose and lower the number of gallons of soft water between regenerations. Most contemporary electronic control valves allow the hardness removal capacity to be set rather than the volume of resin and relying on a predetermined algorithm. That's why the Logix is not a favorite of mine. If you change the settings in your 762 as I have instructed you will use less salt (making the rinse cycle more effective), waste less softened water, and regenerate more frequently than every 10 days which is better for the resin. The changes may mitigate your spotting problem to some degree not withstanding that your softener doesn't actually have a problem. |
- Posted by mrmichaeljmoore (My Page) on Thu, Feb 17, 11 at 13:35
| I got one of the test results from the water sample I dropped off Tuesday. TDS: 476 mg/L (consistent with previous levels) Silica was not done yet...maybe tomorrow or Monday. justalurker: I adjusted the settings on my softener. I did a regeneration last night. I tested the hardness from the cold tap this morning. Hardness measured at 0. I double checked the drain line. No kinks or obstructions. I plan on cleaning the remaining bathroom fixtures this weekend. Just our of curiosity, justalurker, are you a plumber, water treatment guy, chemist, expert DIYer? thanks for your continued help. |
- Posted by justalurker (My Page) on Thu, Feb 17, 11 at 15:29
| Let's see... 2 adults + 1 (2 munchkins = 1 full size person) = 3 x 60gpd (average water use = 180 gpd x 7 + 180 gallons (one days reserve) = 1440 gallons and the 762 says 1600 so it's algorithm is using 20% as a reserve factor (1575 for 7 days with 20% reserve) and I'm using one day's water use so we're close in agreement. It will be interesting to hear your observations on water quality, softened water taste, and spotting... better or worse. |
- Posted by aliceinwonderland_id (My Page) on Thu, Feb 17, 11 at 15:44
| Apologies if this explanation is too simplistic - with no information about your knowledge level, I will attempt to make this clear to the average person with little chemistry background. The sodium on your treated water will NOT got down unless your softener has a serious problem. Period. Picture each resin bead as a ball with a bunch of arms. Each arm is holding a sodium. The arms, however, prefer calcium or magnesium. So, as the calcium (or Mg) flow by, the arms let go of the sodium and grab the calcium. It takes two arms to hold a calcium, so for every calcium that is grabbed, two sodium are released. When your softener regenerates, the brine solution passing through the resin is so strong that it essentially rips the hardness away from the arms and replaces it with sodium again. Excess brine is rinsed down the drain, never entering the rest of your plumbing systems, and the softener is returned to normal service Therefore, sodium content of your treated water depends upon the hardness content of your untreated water (plus, of course, whatever sodium happens to be in your water naturally). Increasing softener salt-efficiency will not change sodium content in your treated water. It will save you some money on salt. That is all, unless your softener is operating poorly and does not adequately rinse the resin after the brine portion of the regeneration cycle. If that is the case, it does not matter what your salt efficiency settings are - you have a poorly operating softener. |
- Posted by justalurker (My Page) on Thu, Feb 17, 11 at 16:03
| Yes Alice stated again and again and again. We can pump 800 gallons of brine into 1.5 cu ft of resin and only the sodium required to exchange for the calcium, iron, and manganese on the resin will stick(?) to the resin beads but inadequate or improper rinse will leave excess sodium in the resin tank. It's obvious to me that the OP's softener seller did little than input the gross settings and took all the defaults so getting the softener as close to correct as possible through the keyboard helps me eliminate some possibilities. If you or I were there then we'd sort this out but we're not. MM hasn't mentioned bringing this problem to his dealer so we don't have any info in that area. All we can do long distance is rule out the obvious and hopefully we'll end up with the true cause of the problem remaining... it's hard looking through someone else's eyes so MM, move the softener closer to the keyboard so we can see it. |
- Posted by mrmichaeljmoore (My Page) on Thu, Feb 17, 11 at 16:30
| ok...is there any way to tell if the amount of sodium in my treated water is appropriate based on my hardness? That way we know if the softener is operating (and rinsing) properly? Raw Hardness 21-22 gpg Do those numbers look reasonable? I also will let you know if there is a difference in taste. I have been communicating with my dealer. They admit that the spotting seems excessive and that is most likely caused by sulfates and possibly sodium. thanks. |
- Posted by justalurker (My Page) on Thu, Feb 17, 11 at 17:15
| MM, I have 30 gpg hard water witth TDS @ 270ppm and there are two of us in the home. I'm not on a well but a rural water system fed by big wells. I have a 1.5 cu ft softener at this time and it is tuned for efficiency and produces absolute 0 hardness water with TDS @ 470ppm. RO under kitchen sink has TDS of 14. I have always used KCl rather than NaCl and have no spotting on chrome surfaces or glass... none. The fixtures in the bath and shower air dry and there are no spots. You and I are on different water but the difference in my before and after softener TDS gives you an indication of how much potassium is exchanged into the hard water to make it soft. Interesting that your TDS went down in the soft water while usually with hard water TDS goes up after the softener to reflect the increase in sodium or potassium exchanged into the hard water to soften it. Perhaps Alice will comment on that cause it confuses me. If I had bought a softener and was having these problems I'd expect the dealer to solve the problem or at least actively participate in finding the solution. I bow to Alice who has far superior chemistry knowledge than me and his ability to explain it but I see what happens in the field and I see what it happens to and how these problems are solved. Th diagnostic commandments say... start at square one and that is to know that the softener is set up correctly which it was not. Then we proceed in an orderly manner checking one thing and eliminating if from consideration, not jumping around from thing to thing and changing everything so we don;t know what had any or no effect. As for your softener operating correctly or not we're blind here on the forum and I don't think your dealer can determine if your control valve has a problem or not. As I said, the Logix controllers are not a favorite of mine. If you had a Fleck control valve or a Clack WS1 CS I'd walk you through increasing the rinse cycle time to see if that has any effect on the spotting. Read through the complete 762 manual and you'll find the area where it discusses changing cycle times and see if it makes sense to you. You said your softener was installed in 2006... have you always had the spotting problem or is that a relatively new problem? |
- Posted by aliceinwonderland_id (My Page) on Thu, Feb 17, 11 at 20:15
| Something is clearly amiss. At this point, however, we don't know for certain if the problem lies with sampling, sample storage or analysis. I suspect the raw water numbers are incorrect. I say this because MM indicated the treated water analysis was done by a lab. Since it was not indicated, I am assuming the raw water analysis was not done by a lab, but rather by field tests. Field tests are wonderful tools in the hands of experienced testers, but can be wildly inaccurate. TDS meters, without proper calibration before every test, are only good for ballpark numbers. Hardness field tests are fairly precise (meaning the same person using the test over and over will typically get the same results), but not very accurate and can be off by an order of magnitude. Na (sodium) levels of 110 mg/L in the treated water, if we assume the raw water level of 25 mg/L is accurate, shows us that 85.7 mg/L Na was added to the water. At 2 Na added per 1 Ca or Mg removed, that's 42.85 mg/L hardness removed, which is only 2.5 gpg. If you actually have 22 gpg hardness, you would expect to see a rise in Na of 752.4 mg/L Na, making treated water Na 777.4 mg/L. You should also see treated water TDS rise by the amount of hardness removed. 22 gpg hardness = 375.2 mg/L hardness. Your water's TDS should rise by approximately that amount after passing through the softener. Some additional questions/comments: 1) How was the sampling of the treated water accomplished? Was the sample cold or hot water? How long was the faucet run or the valve open before the sample was taken? [Samples should be taken from cold water lines only and water should be allowed to run for a minute before sampling] 2) How and where was the raw water sample taken? 3) How long, and under what conditions, did the sample bottle sit before analysis? [Preferably, samples are sealed and store in a cool environment] 4) If any solids settled out, did the lab re-dissolve them prior to testing? [This is not necessarily standard procedure] 5) Were both raw and treated water samples taken at the same time? 6) Who had control of the samples and how were they labeled? Are you certain the correct samples were tested? 7) How was hardness of the raw water determined? What type of test and who did it? 8) How was TDS of raw water determined? |
- Posted by mrmichaeljmoore (My Page) on Mon, Feb 21, 11 at 21:33
| sorry for the delay in responding.... I cleaned all of the chrome fixtures in the new basement bathroom. In order to help prevent spotting, I put Rain-X on the shower door glass and I applied clear spray car wax to all of the chrome and shower door metal. I used Eagle One Nanowax spray: (http://www.eagleone.com/pages/products/product.asp?itemid=1121&cat=50 10). I use it to detail my cars....good stuff.... I used the shower tonight. I will let it air-dry overnight and let you know if there is any spotting. justalurker: As far as noticing the spots....I guess we have always noticed them in the upstairs bathroom....but it wasn't until we did the new basement bathroom (new construction completed August 2010) that we noticed how quick the spots accumulated on the brand new chrome fixtures that I decided to look into the problem. aliceinwonderland: But I did have the raw water tested by the local lab. But they lab report does not have TDS. Just for comparison, the TREATED water results from the same lab, done the same day, on the same sample are: I am waiting for the results of the sample I dropped off last week. In that sample, they are testing for TDS and silica of the TREATED water. I should have those results this this week. To answer your specific questions: 1. Cold water. If I remember correctly, the basement utility sink (no aerator on faucet). I retested the Hardness tonight of the RAW water (using the Hach 5B test kit). Results were about 21 grains per gallon. I pulled the water from the boiler drain of the well retention tank. So, alice, you are saying that the Sodium level should be even higher than the 110.7 calculated by the lab in the TREATED water, if my Hardness is 21-22GPG? Just as a reminder, I have a 4" Big Blue paper filter that filters the water before the softener. And I have a 4" Big Blue Radial Flow Carbon Filter that filters the water after the softener. So, it goes well to paper filter to softener to carbon filter to faucets. You guys have been more than helpful with helping me try to figure out my water problem.....I really appreciate it...but do you think I should contact a local water treatment specialist, who can help diagnose the problem on site? thanks for the continued help. |
- Posted by justalurker (My Page) on Tue, Feb 22, 11 at 10:25
| When you buy water treatment equipment long distance there is no service by definition and you're finding that out. In defense of your online softener seller it is very difficult to resolve these kind of problems long distance because everything is seen and described through eyes other than their own and by (usually) less knowledgeable people. The bitterness of no service lingers long after the sweetness of low price is gone. Are your Big Blue filter housings the 4x20 size? Why are you pre-filtering the water before the softener? Are you having sediment problems? How often are the pre-filters changed? Did you install pressure gauges before and after both the pre and post filter housing to monitor the pressure drop so you'd KNOW when the filters should be changed? You might want to check around locally for an independent water treatment pro who is familiar with the Autotrol-Logix control combo and describe your problem. You'll usually find independents who are intimately familiar with Fleck control valves and fewer that are familiar with the the less popular Autotrol-Logix. If you find one that professes expertise with your control valve ask what they would charge to come out and evaluate your problem. At this point it would be money well spent IF they know what they are doing. Your spotting problem may be that you are exceeding the max SFR of the 1.5 cubes of resin in your softener and hardness is leaking through at the max demand your new shower imposes on the system and softener. It is (unfortunately) too common for online sellers to recommend under size softeners to make it more appealing for the customer to buy a softener cause the price is lower. The answer to your spotting problem is right in front of you and only knowledgeable eyes on the situation or just plain blind luck is going to resolve the problem. |
- Posted by mrmichaeljmoore (My Page) on Tue, Feb 22, 11 at 20:50
| justalurker: I will start looking around for local pro. To answer your questions: 1. The Big Blue filter housings are 4x10 size. 2. When we bought the house in 2003 we had a local water company come out to inspect our water. The recommended a sediment filter and carbon filter to bookend the softener....so we did it. Don't recall if they mentioned a sediment problem. 3. I change the sediment pre-filter every 3 months. The carbon RFC-BB every 6 months. Those were the instructions given by the water treatment company. 4. No pressure gauges. Change the filters based on the calendar schedule above. aliceinwonderland: Silica: 15.9 mg/L I'll let you both know if and when I find a local guy. As a side note, I drank my water for the first time in as long as I can remember..... mm |
- Posted by justalurker (My Page) on Tue, Feb 22, 11 at 21:02
| 4x10 filters are little blue. 4x20 filters are BIG BLUE. 4x10 filters may be too small. Restricting the water flow rate during softener regeneration can result in inadequate backwash and rinse. You might try removing both filter elements and see if that makes any difference. Filter elements should be changed when the pressure drop across the filter approaches 15 psi not by a calendar. you change the oil in your car according to mileage not months. Since you're on a well and there is no anti-bacterial protection in your water be advised that if ANY bacteria is present in your water it will colonize the carbon filter... bacteria LOVES carbon.
- Posted by mrmichaeljmoore (My Page) on Tue, Mar 22, 11 at 12:12
| UPDATE.... I contacted a few local companies. So, unfortunately, my only solution to this problem is to keep up with the maintenance/cleaning of the plumbing fixtures. I bought a TDS meter online. RAW water: 263/338/335 The average TDS is about 336......which, I guess in my case, is high enough to cause spotting. thanks for the help. |
- Posted by aliceinwonderland_id (My Page) on Tue, Mar 22, 11 at 15:41
| A whole-house RO is rarely, if ever, a good solution for a homeowner. You may wish to investigate an anion exchanger, however. Your softener is a cation exchanger. An anion exchanger would remove the silica, among other things. Most water treatment "pros" that deal with home water treatment don't deal with anion exchange because they essentially know very little about water chemistry. If you find someone who deals with commercial water treatment (think large hotels, or small industry like food production) they can help you. |
- Posted by justalurker (My Page) on Tue, Mar 22, 11 at 16:23
| The TDS of my softened (zero hardness) water is in the 600 range and I don't have the spotting problem you have. |
- Posted by justalurker (My Page) on Tue, Mar 22, 11 at 17:03
| Correct previous post to read TDS of my softened (zero hardness) water is in the 475-500 range... |
- Posted by mrmichaeljmoore (My Page) on Tue, Mar 22, 11 at 17:29
| justalurker - You have now officially made more confused than I was before. ugh. lol.... |
- Posted by justalurker (My Page) on Tue, Mar 22, 11 at 18:00
| If you re-read this thread you'll find that around the 25th post in the thread I posted... "I have 30 gpg hard water with TDS @ 270ppm and there are two of us in the home. I'm not on a well but a rural water system fed by big wells. I have a 1.5 cu ft softener at this time and it is tuned for efficiency and produces absolute 0 hardness water with TDS @ 470ppm" The subject of TDS was brought up. It's not coincidental that the local pros said "... the TDS was causing my spotting" cause that's an easy answer. Once all the water treatment hardware is proven NOT to be causing the spotting problem the only thing left is the water chemistry and it's action (or reaction?) with the object getting spotted on. That is what Alice and I have been trying to help you do. |
| This topic may be closed (last post in 2011) but, my problem is identical: 0 GPG hardness, yet well water still leaves a white precipitate that is untouchable by concentrated acids. Because common hardness spots are easily removed by weak acids, I am suspecting a silicate. Am having a quant analysis for this. If you are still available, Mr. Moore, what was your resolution? Any other comments will be welcomed. |
Return to the Plumbing Forum
