| Ugh. Both of my Rinnai hw heaters froze three days ago. Plumbers thawed one out yesterday and I ran water through it all night, and the damn thing froze again last night anyway.
For both, the external pipes have insulation, but the pipes run down the inside of the wall and that's where the problem seems to lie. Can anyone tell me how these are normally insulated in cold weather climates? Before my guys come in and start jacking out bricks to insulate them, I'd like to make sure we get it right. For the record, we had no issues last winter with this, but the weather's been colder for longer than normal. This is an every-ten-years kind of freeze, but I would like to make sure we can withstand it next time. |
| I'm in Michigan and we run them in inside walls or up thru the floor but not inside an exterior wall. |
- Posted by loves2read (My Page) on Fri, Feb 4, 11 at 4:31
| I too am in DFW so know how unusual this persistent, deep cold weather is--and now my backyard has 1 inch of new snow to top it off... It could be that what froze this time is the water coming IN to the tankless--and that is why you get no flow--no new water came in to fill it since you left it running... if the ice is in the cold water feeding the tankless then you still could get water at your cold water faucets in other locations in the house--and I assume your cold water is not stopped from what you said... Adding insulation to pipes inside that exterior wall would not be done through taking off the bricks-- You better get a plumber out to open up the wall behind the tankless and see if they can thaw the line If you can't get plumber out to find/fix the problem before the thaw Saturday then you better go get "key" to turn off your water at the street meter Friday and try to drain the lines to minimize the damage if the pipe bursts... that can be hard to do because those street valves can stick or freeze up themselves--so be careful |
| If they must be in an outside wall then the insulation only goes on the outside. Nothing goes between the pipe and the inside of the house. This give the inside heat a chance to keep the pipe from freezing. |
| These heaters are outside and not freezing because of their freeze protection mode (use energy though) and the heat from units are protecting some of the wrapped pipes but not out far enough? Concentrated heat tape installed up to wall is the best bet. |
| They both defrosted with no problem today, I'm thinking we need hear tape installations as well...as soon as weather permits. Thanks guys! Deb |
| Not to feed/encourage the spammer, but I missed this on the first go-around. Our Noritz is outside, and the exterior pipe is insulated, plus I have a self-regulating heat tape that is under the insulation. I plug it in in the fall and unplug it after the last freeze in the spring. Not uber efficient, but I didn't want to go to the expense/hassle of putting a thermostat on the tape. The pipes are copper, and I suspect conductive enough that the heat tape takes care of the couple of feet that are inside the exterior wall and adjacent to the part that's heated. |
Return to the Plumbing Forum
