Wed, Feb 27, 13 at 15:09
| In a properly glued fitting, does the pipe actually "bottom out" in the hub? Is there a rule of thumb for how far the pipe goes into the hub? Thanks |
| It should bottom out when fully inserted. The cement acts as a nice lubricant when you push them together. Try to give about a 1/4 turn back and forth to make sure the glue spreads completely as you assemble each joint. If you push one together hard when dry it will grab and be hard to separate. The length varies with the pipe diameter. You can measure a female fitting to the stop (or look up the depth in the manufactures catalog). Full time plumbers know the numbers by pipe size. |
Return to the Plumbing Forum
