basement venting
Posted by oldnorskie (My Page) on
Tue, Feb 8, 11 at 10:46
getting ready to cut basement slab to add a bath. i'm re-routing a 3" line from first floor bath to go under the basement slab with (2) 90's for about 15' and tie into an existing 4" c.i. to street. i'll wye into the 3" line from toilet, tub & shower (all less than 6') and 1-1/2" from lav will run into the 2" shower line with AAV under the countertop. am i ok on venting depending on the 4" c.i. line as a wet vent with a vent stack upstream about 18' ? thank you. al
RE: basement venting
sounds to me like there's no real vent, and you are proposing only an AAV and the (so-called) wet venting.
is this reading correct?
yes , that's my plan. will it work reliably?
no. it will not work.
2/ where in your entire house are the real vents?
3/ you will need master plumber input.
the main 4" c.i. line i'm tying into has a vent stack about 18' upstream & services a toilet on the first floor.
The critical distance is the 15' one.
The fact that "the main 4" c.i. line i'm tying into has a vent stack about 18' upstream..." was the one thing you should not have mentioned in your first post, as it is irrelevant and only serves to show how little you know. No offense. I read and re-read your first post many times. It is a bit dense and it takes a while to figure out.
Repeating your "18ft distance" information in another post confirms my hunch and my reading of your situation, and it shows how little you have learned. Go learn and come back. Or, hire a Master Plumber. Or, stop asking if you can do it the way you asked in your first post.
If you post at other plumbing sites you may want to rewrite the first post completely. Please accept this information and advice in the spirit in which it was given. I'm not a plumber; feel free to post again, with new news or to ask for more input from more people.
Hth
thank you for your comments. i should have mentioned that the 3" line i'm re-routing serves a toilet on the first floor and is on a vented stack. so, i have a vented stack at the head of the 3" line and at the head of the 4" main line. does this clarify the drainage issue in the 3"? also have a drawing which might help: http://img204.imageshack.us/img204/3642/basei.jpg
thank you
