Return to the Plumbing Forum
water pressure
orgnova (
Tue, Feb 12, 13 at 10:37
| Hope someone can help. The water pressure is fine for a short time then drops down to about 2/3 the pressure. I have changed the pressure valve 3 times now. The pressure at the valve is 50 psi. Pressure outside the house over 100. What would cause the pressure to drop? |
RE: water pressure
| A bit more info would be helpful. What is your water source, municipal, well, cistern for example? Where do you read 100 psi? I have never heard of water pressures for residential this high, ever. Please explain what and where is this "pressure valve" you have changed 3 times. |
RE: water pressure
| I have 120 psi into my house and then it goes to a pressure regulator to drop it down to 60 psi, which is plenty. |
RE: water pressure
| the water source is municipal. the pressure is over 100 psi is before the regulator valve which drops it down to 50-55 psi. the regulator has been changed 3 times. i cannot find out why the pressure drops after a minute or two after turning on a faucet/shower. thanks for the responses so far. |
RE: water pressure
| Pressure reducing valve. When you replaced it, did you get one with the same rated flow? Can I safely assume that this is a PRV inside your house and not outside on or near the meter? If it's anything like the Watts I have, you can adjust the pressure via the screw on the top upwards a bit. Say like 60psi. |
RE: water pressure
| I think you are on right track |
RE: water pressure
| Sounds like an undersized PRV. |
