Heat Pump info
Posted by Hotrod1952 (My Page) on
Sat, Feb 16, 13 at 6:20
I will soon be purchasing a Heat Pump (air to air) and I was wondering if anyone can explain how the system cycle accomplishes dehumidification?
RE: Heat Pump info
When warm, humid air comes in contact with a chilled surface, such as cooling fins, moisture in the air will condense on that surface where it can drip down and then be drained away. This is possible because warm air can hold more water vapor than cooler air, so cooling air to where it is over-saturated will cause the excess to precipitate out.
RE: Heat Pump info
^^ Which is the same process that occurs in a non-heat pump air conditioner.
RE: Heat Pump info
A1 Plumbing of Baltimore
Baltimore Plumber
We take of your plumbing solution and make solutions.
Licensed and insured by VeteranOwnedBusiness.com
Plumbing service, Repairs, Heating system, Plumbing heating, Water system, Emergency support.
We help guys with the problem for clogs, leak repair, plumbing fixture, backflow prevention and also for 24 hour emergency plumbing.
We are Baltimore plumber with 40 years of experience.
Welcome to A1 Plumbing of Baltimore. We are located in Baltimore city and had been providing professional plumbing services to customers in neighborhoods through the Baltimore area for over 40 years.
General plumbing service, Plumbing repairs made by experienced licensed technicians, Home water treatment systems, Home water purification in Baltimore.
Bathroom Plumbing, Kitchen Plumbing, Basement Plumbing and other services.
The Director of A1 plumbing of Baltimore is Byron Graham.
Find out our unbelievable specialties at our company website.
Just click A1Plumbing of Baltimore.
Tell us what you think about the company.
Here is a link that might be useful: Plumber Master
RE: Heat Pump info
I think A1 Plumbing of Baltimore hires folks that either:
A) Can't read, or
B) Are thieves.
You don't get to attempt to steal advertising space on this site. By doing so, I have to assume you are incapable of reading the site TOU or that you don't care. Either way, were I in the Baltimore area, I would not hire a plumber who is either uneducated or dishonest.
You asked.
