gray water
Posted by garyfla (My Page) on
Fri, Feb 15, 13 at 5:08
Hi
Anyone one know of books or info on setting up plumbing runs for this purpose?? i maintain a very large aquarium with an auto water change and all that water is just going down the drain. What a waste!!! Thanks gary
RE: gray water
Since it is not covered by code you can do about anything you want.
Pump it into a barrel outside and water the garden with another pump in the barrel.
RE: gray water
Hopefully not a salt water aquarium?
RE: gray water
Hi
No,It's a 350 gallon FW tank though the water is maintained at a high pH. Was thinking of running the waste water to an outdoor Bog or marsh garden though the high pH might be a problem?? It changes around 25/30 GPD so talking quite a bit of water
Brick, all my barrels are full of rainwater lol Was thinking more of a gravity fed direct system since i live in s. florida don't have to contend with snow or ice so plumbing could be on the surface, seems a bit too much water for most plants?? gary
