| Two upstairs bathrooms on opposing wall. Bath 1 has shower/tub combo. Bath 2 has shower only. "Stuff" will back up into shower 2 basin during one time only. Only backs up when bathtub in bath 1 is being drained. Wont back up when bathtub in bath 1 is running, only when draining the higher volume from a filled tub.
Have used a Rigid hand powered snake on both. Wife and three teenage daughters, so I'm sure its hair but cant get???? What does it mean that only backs up in bath 2 when tub in bath 1 is drained? Running tub water doesnt do it. Where to snake??? Drain fitting in bottom of tub 1 didnt want to screw back into shoe below tub very easily. New plastic, maybe cross thread...dont want to remove fitting from shoe again. What is best course of action? Chemicals?? On septic and well. Thanks in advance. |
| "What does it mean that only backs up in bath 2 when tub in bath 1 is drained?" If I understand you correctly, if this has always occurred since living there it may be that there's a vertical drain pipe connecting both drains and when draining a tub on one side the water takes the path of least resistance and will bleed over to the other drain, perhaps even with no clog.
| I'd run a snake down the vent pipe from the roof, and make sure it's long enough to reach to the lowest level. I prefer to use powered snakes as they do a better job of snaring the hair clump that may be causing the problem. JMHO |
- Posted by lazypup (lazypup@yahoo.com) on Sun, Jan 22, 12 at 21:47
| You can not snake a tub fixture arm through the tub drain. When you insert a snake in the tub drain it will only go to the Tee of the Waste & Overflow. The correct way is to remove the overflow cover and if you have a lever lift drain stopper you will find a wire connecting linkage attached to the lever on the back of the overflow cover. Pull that linkage up until you can pull the stopper out. Snake the drain through the overflow and it will go straight down through the tee to the trap and through the trap into the fixture arm. |
- Posted by Curtis12321 (My Page) on Mon, Mar 5, 12 at 18:21
| Here is a easy 5 step approach for dealing with clogged drains. 1.Remove the strainer from the drain. You should be able to remove the screws holding the strainer in place and pry it off easily. If you are in the Los Angeles area try a plumber in Tarzana.
Here is a link that might be useful: Tarzana Plumbing
Return to the Plumbing Forum
