Low hot water pressure
Posted by aceh (My Page) on
Tue, Jan 25, 11 at 8:56
My hot water pressure at the kitchen sink is a bit lower than the cold water pressure at same location. (I checked the areator and it's fine) Hot water pressure at bathtub is fine.
Water heater is only 4 years old, kitchen faucet is a single handle type. Any info would be appreciated.
RE: Low hot water pressure
Make sure all the valves are fully open.
Scale can break loose in a water heater and partially obstruct any valves in the line, but the small stop valves under the sink are especially prone.
That is one of the reasons I prefer ball valves for stops that are not visible.
Is there a mixing valve in the single handle faucet that could be clogged or bad?
Problem solved! There was a big chunk of debris lodged in the hot water side of the inner part of the faucet.
