Quickest Least Expensive Method Of Removing Wall Paper Border?
catkin
13 years ago
DECORATING GUIDESQuick Fix: Find Wall Studs Without an Expensive Stud Finder
See how to find hidden wall studs with this ridiculously easy trick
Full StoryCONTRACTOR TIPSThe 4 Potentially Most Expensive Words in Remodeling
‘While you’re at it’ often results in change orders that quickly add up
Full StoryDECORATING GUIDESHow to Remove Wallpaper in 4 Steps
Learn the best way to remove wallpaper with only water (and elbow grease) so your next wall treatment will look great
Full StoryWALL TREATMENTSCan't Find the Right Wallpaper? Make Your Own
For one-of-a-kind walls, just use your imagination. Custom wallpaper is easier and less expensive than you might expect
Full StoryDECORATING GUIDESStencil Your Ceiling for a Luxurious Look
Add interest in one of the least expected places with a decorative detail you can likely do yourself
Full StoryHEALTHY HOMEWhat to Know About Controlling Dust During Remodeling
You can't eliminate dust during construction, but there are ways to contain and remove as much of it as possible
Full StoryREMODELING GUIDES11 Reasons to Love Wall-to-Wall Carpeting Again
Is it time to kick the hard stuff? Your feet, wallet and downstairs neighbors may be nodding
Full StoryBUDGET DECORATINGBudget Decorator: A Most Affordable Gallery Wall
Need to fill a wall on the cheap? See how to make use of something pretty cool you may already have
Full StoryREMODELING GUIDESWhere to Splurge, Where to Save in Your Remodel
Learn how to balance your budget and set priorities to get the home features you want with the least compromise
Full StoryHOUSEKEEPINGHow to Clean Grout — Stains and All
If your grout is grossing you out, this deep-cleaning method will help it look new again
Full StoryMore Discussions
brendainnj
Charlee_MO
Fort Lauderdale Painters · Frankfort Painters · Lehi Painters · Springfield Painters · Stuart Painters · Patchogue Painters · Burlington Cabinets & Cabinetry · Liberty Township Cabinets & Cabinetry · North Bay Shore Cabinets & Cabinetry · Arlington Heights Flooring Contractors · Brookline Flooring Contractors · Monroeville Flooring Contractors · Patterson Flooring Contractors · Temple Terrace Flooring Contractors · Valencia Flooring ContractorsClaire Buoyant
